broken dizzy cap bolt..help?
Old Apr 14, 2006 | 03:36 PM
integra95gsr's Avatar
Default broken dizzy cap bolt..help?
well i planned on changing my dizzy cap and rotor tonight, since ive owned the car for nearly 3 years and never changed it. nor do i know if the previous owner did. so anyways as i was removing the bottom bolt, it snapped! i assume im going to have to drill it out. so my questions are.
is it difficult to remove the distributor, just remove the 3 bolts and slide it out im assuming? also, does anyone know what size tap i'll need to re-thread it?
Old Apr 14, 2006 | 08:18 PM
top
Old Apr 15, 2006 | 01:41 AM
EnzoSpeed's Avatar
Default Re: (integra95gsr)
I've done that .
Luckily, the broken part stuck out enough on the valve cover side that I could grab it with vice-grips and twist it out. Usually, that's what happens if you over-tighten that bolt and it breaks - it will stick out through the other side a little bit.
Old Apr 15, 2006 | 07:36 AM
bah! this is so lame. i hate when stupid things happen..
im going to try and get ahold of an ez-out and see if it will work..
Old Apr 15, 2006 | 09:05 AM
well i have a new issue. the god damn rotor wont come off.. and yes i took the screw out.
wtf this car is really starting to **** me off..lol
any idea's on how to get the rotor off? i tried to pry it off with a screw driver, but i dont want to break the plastic shield that is behind it.. rar!
searching would have worked fine, but since the search isnt working, im SOL!
Old Apr 15, 2006 | 09:16 AM
top
mshields4129
May 23, 2012 12:57 AM
unknown force
Dec 5, 2010 06:50 PM
megaman096
Jun 2, 2006 03:03 PM
sickofitall1113
Jun 2, 2005 12:01 PM
Draggin99Si
Sep 5, 2003 06:43 PM
