Door panel removal
Old Apr 14, 2006 | 02:16 PM
Toroke's Avatar
Default Door panel removal
The hatch I bought has fucked up window regulators. Or I should say the part the handle itself attaches to is all chewed up... Either way, search is down. I've got the panel almost off. I have looked this up before and it said there was something I need to hook and pull out... HELP!
Old Apr 14, 2006 | 02:24 PM
Toroke's Avatar
Default Re: Door panel removal (Toroke)
Bump. I'm outside with the socket set, flashlight, and a wire hanger waiting to do this.
Old Apr 14, 2006 | 02:30 PM
TurboEM1's Avatar
ok i just did this so here you go.
1. open the door
2. remove the speaker cover and three screws that hold in the speaker
3. remove three more screws that hold the door panel on right around the speaker
4. remove one screw under the door handle/lock part
5. remove one screw in the tray thing that you put your hand in to shut the door
6. pull on the panel to pop out the clips. start at the bottom front and work your way back on the bottom.
7. once there all off pull up and back on the panel to get the top off. it sits in a little groove.
then ur done
Old Apr 14, 2006 | 02:35 PM
Toroke's Avatar
Default Re: Door panel removal (TurboEM1)
There's no clip or pin on/by the handle? EG by the way.
Edit: this
http://img464.imageshack.us/my.php?image=19ta.jpg
Modified by Toroke at 4:52 PM 4/14/2006
Old Apr 14, 2006 | 03:02 PM
TurboEM1's Avatar
o ok. you have an eg with no power windows. I have a 99 si so its different. All i had to do was unplug the wire harness for the power windows.
Ive done it on my crx which has no power windows. That clip is in there and is the biggest bitch to remove. They even make a special tool for removing it. Best bet is to try and move the panel in a lot and get a screw driver to pry it out. sorry i couldnt help more.
Old Apr 14, 2006 | 03:04 PM
DuVaL rAcEr's Avatar
ok... i did this about 2 weeks ago
1 unscrew the screw in the door handle/lock thing
2 unscrew the screw in the tray thing
3 pop the pin out from behind the window crank(i used a kitchen knife)
4 pop all the clips that hold the panel on(like 4 of them i think)
5 lift up and out on the panel
6 do what ever the hell your tryin to do
Old Apr 14, 2006 | 03:55 PM
Toroke's Avatar
Default Re: (DuVaL rAcEr)
Ooookay. I got it, thanks guys. Once I found out about that pin, it was tons easier.
For future reference, I just got some small vice grips, pushed the door panel back a bit, and clamped them down on the two ends of the pin. That little bitch flew right out. Simple.
Thanks again!
Modified by Toroke at 7:04 AM 4/15/2006
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
96teggynonVtec
Feb 18, 2006 02:22 PM
206civic
Jan 8, 2005 11:43 AM
*Boostwerks*
Sep 13, 2002 08:52 AM
teg95
May 22, 2002 01:16 PM
