***remove motor mount?***
Old Apr 14, 2006 | 01:40 PM
sik94hatch's Avatar
Default ***remove motor mount?***
I got a '92 Si. The motor mount thats to the right & down low. Its like a bracket bolted to the block, then bolts under the frame rail.
Can i remove it? What if i put in poly inserts......
Old Apr 14, 2006 | 03:30 PM
thahuhstunna's Avatar
Default Re: ***remove motor mount?*** (sik94hatch)
not quite sure what you are trying to do... i know you're talking about the driver side mount, but not sure what you are trying to do with it...post somemore info and i'll be happy to help if i can
Old Apr 14, 2006 | 04:39 PM
sik94hatch's Avatar
Default Re: ***remove motor mount?*** (thahuhstunna)
Ya, its on the drivers side. Down low, not the top one....
CAN I REMOVE IT? Will i have to put in poly inserts on the other mounts?
Old Apr 14, 2006 | 04:43 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
ya u can but but why?
EG1.8cT68's Avatar
that i belieive from your description is the drivers torque mount, you can remove it if you want, i removed mine and filled the rubber peice that always breaks with 3m window weld and let it dry for 2 days then reinstalled it but some people just leave them off
Old Apr 14, 2006 | 05:16 PM
SkRiBLaH's Avatar
Default Re: (EG1.8cT68)
ive never ran that mount. extra weight and the other 4 do a fine job.
ConceptVBS
Honda Civic (2001 - 2005)
Apr 17, 2014 06:14 AM
imadigitalgod
May 29, 2010 11:32 PM
D
Feb 9, 2010 06:15 AM
94delslo
Sep 24, 2007 06:26 PM
mattL
May 25, 2004 12:32 PM
