switch to obd1?? or stay non obd
Old Apr 14, 2006 | 04:36 AM
slow91crx's Avatar
Default switch to obd1?? or stay non obd
well i have my poor man's type R in my crx now, its a b16 head on a gsr block with pr3 pistons and ctr cams... QUESTION is... im running a chipped pr3 ecu with a chip that i had a guy custom burn for me... but im worried that his burn is not close enough to make my motor run correctly.. should i just get another chip burned and get the timing and cam gears and fuel pressure set on the dyno?? or should i spend a couple hundred bucks and switch to obd1 and run a p28 with uberdata?? any comments are appreciated, thanks
Old Apr 14, 2006 | 04:37 AM
slow91crx's Avatar
Default Re: switch to obd1?? or stay non obd (slow91crx)
the car runs right now, just has a tiny " miss" at idle, almost can't tell its doing it... plus for some reason it has a fuel cut rev limit at 7800... which i need to get rid of for sure..
hondapunkrock
Aug 8, 2008 01:04 PM
slow91crx
19
May 5, 2006 10:51 AM
slow91crx
May 5, 2006 07:53 AM
slow91crx
Apr 17, 2006 04:34 PM
trustnoone7935
Jun 11, 2005 08:27 PM
