vtec engagement
Old Apr 13, 2006 | 11:48 PM
JDMtype Eg6's Avatar
Default vtec engagement
when i hit vtec in 2nd-5th gear at 5500 rpms it feels like im letting off the gas a little once it engages. Wondering if this is normal. or how i can diagnose this problem. thanks
<U>mods</U>
b16a sir2
Blox IM
DC 421 header
B&M FPR (currently at 43 psi)
2.25" piping w/no cat
Old Apr 14, 2006 | 01:22 AM
kikoy's Avatar
Default Re: vtec engagement (JDMtype Eg6)
thats the same problem im having right now. when vtec engages it hesitates but when i reach 6000 rpm it's bck to normal. did you change your valve train? what cams are you using?
Old Apr 14, 2006 | 01:31 AM
Default Re: vtec engagement (kikoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikoy &raquo;</TD></TR><TR><TD CLASS="quote">thats the same problem im having right now. when vtec engages it hesitates but when i reach 6000 rpm it's bck to normal. did you change your valve train? what cams are you using?
yup, at 6k its back to normal for me too. The guy i bought the motor from said it had itr cams but i doubt it. Never opened the head. So basically stock cams and valvetrain.
Old Apr 14, 2006 | 02:20 AM
xd69's Avatar
get a vtec light
Old Apr 14, 2006 | 02:21 AM
kikoy's Avatar
mine when i was still using stock b16a cams it was working fine. but when i changed to skunk2 stge2 and changed my valvetrain to skunk thats when the problem started. i cant seem to diagnose the problem.
Old Apr 15, 2006 | 04:52 PM
any other imputs?
Old Apr 15, 2006 | 04:54 PM
i dont think its a fuel problem because ive adjusted it from 40-50 psi and still the same problem.
Old Apr 17, 2006 | 06:58 PM
efb20vtec's Avatar
Default Re: (JDMtype Eg6)
hey can i run my wire from my vtec solenoid without the clip??run the cut wire straight to the ecu??reason is cause i cant find a clip for that...if i do run the wire without clip will it throw check engine?help please
Old Apr 17, 2006 | 07:55 PM
so lazy's Avatar
probably just your getting kicked out of VTEC once you shift gears... thats how it feels in a b16a... cause i had a jdm b16a in my DA and each time i shifted i was knocked out of vtec and it engaged again.. so that could be your problem i'm not saying it is but it could be.. so good luck on that buddy.
Old Apr 17, 2006 | 08:45 PM
blk007's Avatar
Default Re: vtec engagement (dc2-guy)
this is funny..i just came in here to post up to say i'm having the same if not similiar problem and i came across this thread mine feels like there's a hestitation too.like it doesn't engage like it used too. i didn't change the cams or valvetrain. stock jdm b16a w/chrome chipped ecu. what sorta things cause your vtec to not engage properly or not as vibrant? no vtec check engine lights.
Old Apr 17, 2006 | 09:33 PM
confusatron's Avatar
Default Re: vtec engagement (blk007)
1. faulty speedometer signal, your speedometer will be spastic and erratic
2. faulty vtec solenoid or loose wire connection
3. dirty or faulty 02 sensor.
I've had problems with all three at one time or another, sometimes all 3 at the same time.
Old Apr 17, 2006 | 11:26 PM
Default Re: vtec engagement (confusatron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confusatron &raquo;</TD></TR><TR><TD CLASS="quote">1. faulty speedometer signal, your speedometer will be spastic and erratic</TD></TR></TABLE>
thats exactly whats wrong with my car now, also my speedo would work on and off while im driving. I took out the speed sensor to clean it a little and placed it back, the speedo was working fine but still the needle hesitates a little. Is there a way to fix this problem? thanks
Old Apr 19, 2006 | 05:25 AM
blk007's Avatar
confusatron you're right. i also was having problems with my speedo...exactly what you said.changed the vss and it still did it. then i looked at the actually plug,it wasn't attaching properly, also was dirty and corroded(most likely causing shorting).cleaned it,speedo works fine but still same problem. i'm gonna check the solenoid filter.i heard you can clean it or do you replace it?
Old Apr 19, 2006 | 12:06 PM
you can clean the solenoid filter yourself, just take the 3 bolts off and take the gasket(solenoid filter) off and clean it with oil.
00_JDM_EM1
10
Sep 15, 2008 11:32 AM
1sikhatch
May 13, 2007 04:37 PM
ivicr
Jan 10, 2007 01:48 PM
kikoy
13
Apr 13, 2006 09:01 AM
RiSiNgDc2
Mar 11, 2006 09:08 PM
