Bodywork question...
I also posted in the Welding/Fabrication section to see what answers i can come up with.
I own a 90 CRX SI and i want to swap over my USDM front end for a JDM siR front...
here is my question though, Is it possible to swap the USDM CRX front onto an 88 civic sedan? (anything is possible with money... but realistically, how hard is it?)
I'd like to use the hood too.... (Metal JDM ZC hood)
I really like the USDM CRX front bumper better than the civic front, so i'd like to use that too.
I do understand that the hoods are different sizes and the fenders arent an exact match either... so i'd like to cut portions of the CRX fenders out, and add the civic fenders.
most likely going to swap out the D15 from the sedan and drop in my supercharged D16a6 into the sedan..... have a fun little daily driver/project.
i got even bigger plans for my CRX.
If its too much of a pain....
I know i have seen the wingswest/mugen style kits installed on sedans... what does it take to do the complete kit? front and rear bumper should be straight forward, if i were to buy two sets of side skirts and door caps, would i have enough material to do the sides too?
they are.... but i know with a little fab/modification, its possible.
hell we've seen nasty *** widebody CRXs with prelude taillights and RSX head lights..... if thats possible, so should what i want to do.
Definitely possible. As you stated above, anything is possible with enough money. Hell, I bet you could even weld an R34 front on there with enough money hahaha
Anyways, I have no idea what you need to do to get it to fit, but if people can stick teg' and EK front ends onto CRX's, you should be able to fit a same generation JDM/USDM Rex' front end on there no problem. Good luck!
. Anyways, I have no idea what you need to do to get it to fit, but if people can stick teg' and EK front ends onto CRX's, you should be able to fit a same generation JDM/USDM Rex' front end on there no problem. Good luck!
Don't quote me on this, but I think I read about a guy doing this on h/t about a year ago. I think the plan was to cut the fenders right where the molding is. Weld them together using the top from the CRX and the bottom from the sedan. I THINK it fits if you do that.
Once again, don't be mad at me if this doesn't work. Do you research first, but i'm pretty sure that's the way to make it fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko »</TD></TR><TR><TD CLASS="quote">Don't quote me on this, but I think I read about a guy doing this on h/t about a year ago. I think the plan was to cut the fenders right where the molding is. Weld them together using the top from the CRX and the bottom from the sedan. I THINK it fits if you do that.
Once again, don't be mad at me if this doesn't work. Do you research first, but i'm pretty sure that's the way to make it fit.</TD></TR></TABLE>
thats what i was planning on doing.
we'll see. i think it would look HOT.... if it doesnt work, oh well, not the end of the world, i'll just have an extra CRX fton laying around in my garage.
was saving for a stroker D16a6...
i have around $8,000 to spend on a motor and the endyn supercharger (much better than the jackson i have now)...but, now that im buying a beater, (88 civic sedan) i figured i'd tune the stock D16a6 with the JRSC at 8-10 PSI and swap it into the beater.
with the money i have saved, Im shopping around for a k20R for the CRX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
GOD DaMn. Everbody is going for K20!!!!!!!!!
Good luck man.
</TD></TR></TABLE>GOD DaMn. Everbody is going for K20!!!!!!!!!
Good luck man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote">
Good luck man.
yeah.... too bad what i have saved isnt enough yet.
maybe for the type S, but i want the RRRRRRRRRRRR!
Good luck man.
</TD></TR></TABLE>yeah.... too bad what i have saved isnt enough yet.
And those who have them want the K24.
blaak-crx
Jun 5, 2008 08:28 AM
Double Agent
Mar 29, 2006 09:40 AM
