how is the HF turbo manifold for D16Z6 turbo?
like the title says.
we want to build another turbo project and we want to use this HF manifold
is it good manifold? any one use that before???
thanks
roy
thanks
roy
we want to built an d16z6 turbo that boostin 0.6 bar
dont want a big setup just somthing nice for my boy
daily drive
thanks
daily drive
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">it will work fine</TD></TR></TABLE>yup 220whp and counting here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu »</TD></TR><TR><TD CLASS="quote">has anyone got this thing to work with ac yet??</TD></TR></TABLE>
its not gunna work with a/c, i dont think a single person has had it work with a/c sorry man
this is a tried and true option, you can get a plate for $50 (check here, hmt) to make it a bolt on affair, or else you can make a plate if you have the equipment. if you have a welder, you can get a log mani kit for $100 or buy the flange and bends separate for even less. depends on what you want and your budget. i think the adapter plates are well worth the money. use factory gaskets also, add an oil line setup and you're getting pretty close. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx »</TD></TR><TR><TD CLASS="quote">this is a tried and true option, you can get a plate for $50 (check here, hmt) to make it a bolt on affair, or else you can make a plate if you have the equipment. if you have a welder, you can get a log mani kit for $100 or buy the flange and bends separate for even less. depends on what you want and your budget. i think the adapter plates are well worth the money. use factory gaskets also, add an oil line setup and you're getting pretty close. good luck</TD></TR></TABLE>
Where can I get this log mani kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 »</TD></TR><TR><TD CLASS="quote">good old HMT
</TD></TR></TABLE>if you can get past all the BS on that site, there is actually a TON of good info over there.
Modified by ryan89crx at 3:02 PM 4/15/2006
A 4-1 equal manifold is supperior in power all the way up to 400whp. Port it out with a hand tool or whatever to increase spool up some and you have yourself a nice street manifold. Not to mention at the fraction of a "high performance" manifold.
