Suspension & Brakes Theory, alignment, spring rates....
ground control adjustable perch bolt broke in half
Old Apr 13, 2006 | 09:27 AM
sinfulj32's Avatar
Default ground control adjustable perch bolt broke in half
so the allen bolt that you tighten and loosen to spin the perch on the coilovers broke. does eibach have warranty on their groundcontrols? in the mean time how do keep my perch from spinning freely while driving getting lower-higher?
Old Apr 13, 2006 | 09:33 AM
Voyage34's Avatar
Default Re: ground control adjustable perch bolt broke in half (greenej8)
yes there is a warranty, lifetime i believe.
Old Apr 13, 2006 | 09:36 AM
sinfulj32's Avatar
Default Re: ground control adjustable perch bolt broke in half (Voyage34)
i looked on their site and they dont even show ground controls anymore. and they dont have anything on warranties either.
Old Apr 13, 2006 | 09:39 AM
Tyson's Avatar
they have a number to call.
530 677 8600
Old Apr 13, 2006 | 09:40 AM
Voyage34's Avatar
http://www.ground-control-store.com/ seems to have them still
Old Apr 13, 2006 | 10:06 AM
94eg!'s Avatar
#1 Super Guy
Loved
Eibach doesn't make ground control's parts. Ground control just uses eibach's springs in their kits. If you have a problem with any part of your GC kit, you should contact ground-control directly for replacments...
All parts of the GC kit should be warrantied for life...
As for driving, you should be okay. Just keep an eye on the ride height every time you get out of the car. Don't worry, nothing will break or explode...
Old Apr 13, 2006 | 11:53 AM
slammed_93_hatch's Avatar
Default Re: ground control adjustable perch bolt broke in half (94eg!)
how the hell did that thing break?
just an FYI, they don't need to be cranked down on, just get it tight enough so that the perch doesn't move.
Old Apr 13, 2006 | 02:43 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: ground control adjustable perch bolt broke in half (slammed_93_hatch)
Call GC, they will take care of you: 530-677-8600
Old Apr 13, 2006 | 07:32 PM
Budget EJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
just an FYI, they don't need to be cranked down on, just get it tight enough so that the perch doesn't move.</TD></TR></TABLE>
Damnit! I definitly made sure mine were "secure" and probably overtightened Hope mine doesn't break next time I adjust!
Is GC's bolt/perch system really better than the two perch/lock system?
Old Apr 13, 2006 | 09:29 PM
Tyson's Avatar
Default Re: ground control adjustable perch bolt broke in half (Budget EJ)
personally i think its a much better system of tightening the perch than the double jamnut. you dont need a spanner wrench to break it loose, and you really dont need to gorilla the bolt tight. just a good wrench with the wrist is all you need.
Old Apr 13, 2006 | 10:15 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ground control adjustable perch bolt broke in half (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">personally i think its a much better system of tightening the perch than the double jamnut. you dont need a spanner wrench to break it loose, and you really dont need to gorilla the bolt tight. just a good wrench with the wrist is all you need.</TD></TR></TABLE>
Mine are stuck and I can't get them loose.
Not to mention the broken Eibach spring.
Old Apr 13, 2006 | 10:16 PM
Tyson's Avatar
Default Re: ground control adjustable perch bolt broke in half (JDM_Ej)
did you ever follow thru with talking to eibach or gc about that?
i still wanna see pics.
Old Apr 13, 2006 | 11:54 PM
saveacivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget EJ &raquo;</TD></TR><TR><TD CLASS="quote">
Is GC's bolt/perch system really better than the two perch/lock system?</TD></TR></TABLE>
no, Ground Control released the "adjust with one hand" gig in 1999 to counter VIS's claim that their coilovers were the easiest to adjust. (dont you guys remember the pics in super street of the guy adjustiing his silver ek with one hand? go check your old super street mags for it, hilarious today...) it was a cheesy slogan but it worked. we sold those kits on sale for $299 and had to re-order a dozen more every week.
-that bolt is notorious for freezing up due to overtightening. all companies had their flaws. even Skunk 2's coilover kit had probs with the spring seat sliding down the perch, killing the threads. both companies stood behind their products though, you should have no problem getting it replaced direcly.
Old Apr 14, 2006 | 12:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: ground control adjustable perch bolt broke in half (saveacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">did you ever follow thru with talking to eibach or gc about that?
i still wanna see pics.</TD></TR></TABLE>
Not yet. I want to get pics of the spring first. I haven't been to my shop in a week or so because of my horrific work schedule. I will get pics this weekend though.
Old Apr 14, 2006 | 11:58 PM
HiProfile's Avatar
The way it works, it slightly deforms the threads when they get snug - deforms in the sense that they are no longer in line with each other (parallel). That puts friction on the bolts like a nylon locknut. The perch should have enough friction from the 700lbs or 400lbs of vehicle pushing them down onto the sleeve's threads to not move even w/o a bolt (bottom of sleeve contacts less surface area on the shock). Road grime alone will slightly 'glue' the perch to the sleeve enough to prevend major movement.
BTW, I do remember those types of adds. I think it was the one with the bleached spikey hair, right?
pjr710
Suspension & Brakes
May 11, 2009 09:53 AM
lee0149
Suspension & Brakes
16
Jan 30, 2009 05:56 PM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
PA MATT
May 5, 2004 06:54 AM
Mr HYDE
Dec 20, 2003 01:32 AM
