trouble with ground control coilovers
Old Apr 19, 2004 | 05:29 PM
PA MATT's Avatar
Default trouble with ground control coilovers
i went to lower my car for the good weather ahead and i can't seem to get the sleeve to turn after i loosened the allen bolt. ground control doesnt have a tool to spin it so does anybody have any tips or suggestions for me? ive never had this problem before and appreciatte any help
Old May 4, 2004 | 07:21 PM
atisvt99's Avatar
Default Re: trouble with ground control coilovers (ebpG2)
I'm doing worse then you... I went to raise my car up a little for some 16s that I'll be putting on and couldn't get the allen bolt lose. So I ended up removing the whole assembly and after soaking the sleeve and allen bolt in wd40 for 30 minutes, STILL ended up with a stripped allen bolt head. So now I'm fucked... not sure what my options are, if any... the sleeve is made of pretty light weight aluminum, so I can't drill the bolt out... I don't suppose GC sells the sleeves individually or has any sort of warranty? Ish...
Old May 4, 2004 | 08:21 PM
BlackCivSi's Avatar
if you are changing the front or back, you have to make sure both front wheels are at even height, or both back wheels are at even height.
the sway bar restricts you from changing the height of the coilover because of the pressure going against it. was this the problem you were having?
Old May 5, 2004 | 04:42 AM
PA MATT's Avatar
Default Re: trouble with ground control coilovers (BlackCivSi)
i ended up finding a tool i used to change bike tires and kind of pulled the sleeve around with that and used a flat bar and lightly tapped it with a hammer...worked pretty good
Old May 5, 2004 | 06:54 AM
esoterEK..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpG2 &raquo;</TD></TR><TR><TD CLASS="quote">i ended up finding a tool i used to change bike tires and kind of pulled the sleeve around with that and used a flat bar and lightly tapped it with a hammer...worked pretty good</TD></TR></TABLE> that's what i was about to say. Yeah after a while dirt and rubbles get all up in the sleeves.
Xathine
Suspension & Brakes
Nov 6, 2008 12:51 PM
sinfulj32
Suspension & Brakes
14
Apr 14, 2006 11:58 PM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
B HATCH
Apr 3, 2004 11:16 PM
sbrocks1
Mar 14, 2002 04:24 PM
