brake light problem??
Old Apr 12, 2006 | 07:24 PM
ci_v_ic's Avatar
Default brake light problem??
has anyone ever had the brake light switch "stick" to where the brake lights are on all the time?? please give me some input here tia.
Old Apr 12, 2006 | 07:54 PM
ci_v_ic's Avatar
Default Re: brake light problem?? (ci_v_ic)
bump comeon please help me.
Old Apr 12, 2006 | 08:08 PM
gsxr1k05's Avatar
replace the switch..
Old Apr 12, 2006 | 08:15 PM
ci_v_ic's Avatar
Default Re: brake light problem?? (gsxr1k05)
thats the only response i get?? replace the switch. wow this is a great forum.
so theres no way to test the switch?
Old Apr 12, 2006 | 08:19 PM
harmonator84's Avatar
well buddy do you expect for ppl to just post in like 1 sec.
calm down
build the post and they will come
hehe
Old Apr 12, 2006 | 08:32 PM
ci_v_ic's Avatar
Default Re: brake light problem?? (harmonator84)
why do people on this website continually post **** that DOESNT HELP. not tryin to be an ******* but im needin to get this fixed by in the mornin so i can get to work. this is my daily driver not just some project car i got.
Old Apr 12, 2006 | 08:45 PM
sanimalp's Avatar
$cat /dev/urandom
replace the switch then.
unless you think it isnt the switch, in which case you would need to provide information on why you think it is not. if the rear half of your car was missing, and didnt tell us that, we would just say replace the switch. we would not say "hey you need a new rear half of car".
the switch is plastic and plastic breaks sometimes when it is used repeatedly over 15 years. and since it only cost like $10 it may save you some money to replace it and find out that was what was broken.
Old Apr 12, 2006 | 10:34 PM
ALLMOTORCRX20's Avatar
your going to need a multimeter.
there are two wires on the brake switch.
I believe they are white/green and green/white.
The white/green wire should read 12 volts
The green/white wire should only read voltage when the pedal is pressed
or when the pedal is depressed. One of the two, but not both.
If you get voltage when the pedal is out and when the pedal is in, then you need to replace the brake switch
Old Apr 12, 2006 | 10:49 PM
gsxr1k05's Avatar
Default Re: brake light problem?? (ALLMOTORCRX20)
well, so sorry you dont like my advice. if you wanted to test the switch, get a multimeter and do a continuity test. but at least i tried to help you out.. no need to get pissy about the FREE help.
KelvinR
Sep 10, 2012 02:38 PM
irondragon013
Jun 28, 2008 02:03 PM
geneva
Jun 11, 2008 05:46 PM
honda1982
Mar 31, 2008 01:23 PM
