Which Throttle Cable/Bracket to use with AEBS GSR I.M.?
I will be swapping in a B18C1 with an AEBS Intake Manifold in my del sol shortly but I was wondering what throttle cable to use and bracket?
well your in luck, my friend just did the exact same setup in his del sol. he used the throttle cable bracket from a 94-95 gsr, problem is, when you close the hood or move the cable around it messes with the idle. they sell aftermarket throttle cable brackets, thats your best bet, it will mount on the two holes on the third runner on the manifold, oh yea, when he put that manifold on it actually made his car slower. tooooo much air, not enough fuel so think about some kind of fuel management after your done, or you will not be impressed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saccord »</TD></TR><TR><TD CLASS="quote">well your in luck, my friend just did the exact same setup in his del sol. he used the throttle cable bracket from a 94-95 gsr, problem is, when you close the hood or move the cable around it messes with the idle. they sell aftermarket throttle cable brackets, thats your best bet, it will mount on the two holes on the third runner on the manifold, oh yea, when he put that manifold on it actually made his car slower. tooooo much air, not enough fuel so think about some kind of fuel management after your done, or you will not be impressed</TD></TR></TABLE>
I have a FPR and Hondata. Also Planning on doing a direct port since I heard that this manifold already has holes for it on the under side. Is this correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollydc69 »</TD></TR><TR><TD CLASS="quote">ITR throttle bracket will work. </TD></TR></TABLE>
should I get that cable too or can I use my stock del sol one? Im thinking that I still can use it. I also have a LS Throttle bracket will that work just as good as an ITR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK »</TD></TR><TR><TD CLASS="quote">
should I get that cable too or can I use my stock del sol one? Im thinking that I still can use it. I also have a LS Throttle bracket will that work just as good as an ITR?</TD></TR></TABLE>
I dont know about LS, I have a AEBS manifold on my hatch and i only used the Type r bracket.
Is your LS look like this???
Modified by rollydc69 at 5:53 AM 4/15/2006
GSR-TRBO-DA
Jan 13, 2008 04:30 PM
JDM00SI
Jan 22, 2006 02:06 PM
