Filling the Tranny
Old Apr 12, 2006 | 04:21 PM
pinecone's Avatar
Default Filling the Tranny
Alright I went to change my tranny fluid today. I was trying to take the filler bolt off and stripped it into almost a circle( I wanna beat whoever put it back in that tight, unless it has never been taken off from the factory).
How do I get the bolt off? Also is there any other way to fill the tranny? I read that you can fill through the speed sensor, but does that mean you have to fully remove the whole housing for the sensor.
I have a 91 Hf w/ a Z6 and a 91 Crx Si tranny.
Old Apr 12, 2006 | 05:09 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
The filler bolt? As in the square-holed one?
You are dicked.
Old Apr 12, 2006 | 05:20 PM
ludesrv's Avatar
Default Re: (VashTheStampede)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">The filler bolt? As in the square-holed one?
You are dicked.</TD></TR></TABLE>
He means the 17 mm bolt on the back end of the tranny.
Let me tell you our trick for messed up bolts, you easy out them, then you get a new one from Honda, they cost hardly nothing, or you can get a new one from a scrap yard in any honda manual tranny.
Old Apr 12, 2006 | 05:38 PM
SFlCrx's Avatar
or u can vice grip it and replace it with an oem plug and always remove the fill plug on everything before the drain plug for the future
Old Apr 12, 2006 | 05:41 PM
EF_ST@TUS's Avatar
get ahold of a file make it a 14mm
Old Apr 13, 2006 | 03:33 PM
pinecone's Avatar
Default Re: (Lost_in_a_world_so_cold)
Well vice gripping it did absolutely no good. The bolt is a nice circle. I am beginning to think this plug has never been pulled in 15 years. So an easy out is my only way, will it even fit in to get the bolt, since there is not even enough room for a socket.
Is there any other way to fill the tranny?
Would removing the fill plug have even helped in a case like this, I doubt it.
Old Apr 13, 2006 | 03:36 PM
gsxr1k05's Avatar
Default Re: (pinecone)
remove the speed sensor, get a skinny tall *** funnel, and fill 'er up
Old Apr 13, 2006 | 03:38 PM
pinecone's Avatar
Default Re: (gsxr1k05)
I'll have to see if I can work it out with a set of vice grips.
Old Apr 13, 2006 | 03:53 PM
highrev1987's Avatar
try to fill it from the plug under the starter.
Old Apr 13, 2006 | 04:02 PM
pinecone's Avatar
Default Re: (highrev1987)
What does the plug under the starter look like?
Grrr, this **** is annoying. Why do people have to tighten the bolt so much, freaking ridiculous.
Old Apr 13, 2006 | 04:21 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Under the gold colored 19mm hex.
On stuff like this,make sure you use a six point socket
or six point box end wrench otherwise it will just round off..
Cheap tools often provide bad results..
You might try a good (rigid) pipe wrench like for plumbing to
get the fill plug out as it is designed to turn pipe which is round...
Old Apr 13, 2006 | 04:43 PM
pinecone's Avatar
Default Re: (88DXCRX)
Hmm, if only my tranny was pulled would that be easy to get to.
Should I pull the passenger side tire off to get to that plug?
Do you have a bigger pic of that?
Old Apr 13, 2006 | 04:46 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">remove the speed sensor, get a skinny tall *** funnel, and fill 'er up</TD></TR></TABLE>
Old Apr 13, 2006 | 04:57 PM
you dont need to take the trans out. that thing in the pic is right under the starter, so take that off and there it should be.
Old Apr 13, 2006 | 05:04 PM
pinecone's Avatar
You guys must have small hands or small tools, cause you make it seem so easy to get to these pieces and get them off, lol. I will look into the starter plug tomorrow.
Old Apr 13, 2006 | 05:32 PM
shortyz21's Avatar
one time i had to lay under a guys car, and kick the end of the wrench ******* hard to get that basterd out.
i found the only thing that gets that bolt unstuck is tapping power, not constant torqueing pressure..
when u fill it make sure u get the specs on how much to put in, since u cant use your filler hole for the right level..
Old Apr 13, 2006 | 06:16 PM
pinecone's Avatar
Default Re: (shortyz21)
I'll have to look into it tomorrow.
Old Apr 14, 2006 | 12:23 AM
FOMULA91's Avatar
The thing I did was to fill it up from the drain plug. Ask one of your friends and unbolt the drain plug, so it is completely empty. After that, buy the gear fluid (the tip should be sharp) and squeeze (force) it in and when you get about 1/3 in, take it out and make your friend cover it with their thumb (it will leak fast, so do it quickly). Refill the bottle so it if full again and repeat the process over until you put in like 2 quarts.
The tricky part is to put the drain bolt back.
IA95civicDX
May 15, 2009 10:29 PM
jimmyrab
May 20, 2008 07:03 AM
S1NFUL RL1 619
Mar 18, 2008 04:36 PM
Weel
Mar 13, 2006 10:28 AM
trooper0641
Feb 4, 2005 04:15 AM
