Rear Defogger bulb
My bulb blew out in the rear defogger, I took apart the switch but I am not sure how to get the bulb out of the housing. I tried to search for bulbs and I am not even sure what name the bulb is, its very small, and it only goes on when the parking light/headlight switch is turned on. (when it worked) I believe cruise control has the same bulb. (the bulb i am talking about is not an LED, its not the light that goes on when the defogger is pressed)
You twist the socket counterclockwise and use a small flathead to pry it out without breaking the housing if it doesn't come out by inverted the switch already. I belive you can only get it at Honda, the sucker is very small.
Thanks but it seems pretty difficult to reach in there to turn it, Are you thinking of the integra defogger switch or a civic 92-95?
qat727
41
Feb 4, 2010 07:49 PM
