idle rpm problem
Old Apr 11, 2006 | 10:49 PM
ForceXVII's Avatar
Default idle rpm problem
why does the needle fluctuate up and down (1500rpm, 900rpm) during idle & neutral. hit me up, thanks
95 Accord EX manual
Old Apr 12, 2006 | 06:33 AM
accord-pro's Avatar
Default Re: idle rpm problem (ForceXVII)
chk for a vacc leak, make sure you have planty of coolant, chk to make sure adjuster screw at throttle body is not all the way out,
Old Apr 12, 2006 | 07:30 AM
StyLz's Avatar
My 96 has done this from time to time as well. Usually depends on the air temperature. Does it all the time in the winter but as soon as it's above freezing it stops.
Old Apr 12, 2006 | 08:14 AM
92ehatch's Avatar
Default Re: (StyLz)
mine did this as well.
things i did/replaced
pcv valve and hose (hose on mine was collapsed)
cleaned IACV- take off the car, spray carb cleaner in it until its clean
adjusted FITV- take off cap, screw the thermowax plunger down until its snug.
fixed the problem for me
take in mind this is on a 93, but the concept is the same
JFantastic
Mar 11, 2013 08:15 PM
dth0ng69
25
May 18, 2009 08:30 AM
90civicSi VTEC
19
Sep 27, 2008 05:55 PM
averyvm
17
Jan 17, 2007 11:51 AM
R. Mack
Jun 1, 2005 07:55 PM
