Do I have a bad Differential? b16 tranny help
Old Apr 11, 2006 | 09:38 PM
tommyj's Avatar
Default Do I have a bad Differential? b16 tranny help
I think I may have a bad Differential but I am not 100% sure. The tranny is a 2000 b16a2 with 45k on it.
From a stop and driving through 1-3k I hear a loud POP from the transmission. After that I hear no problems. While driving I have no problems. The car shifts fine into all gears. I jacked up the car and spun both wheels, the opposite wheel does not budge. However it does make this loud clicking noise which I have recorded below:
http://home.comcast.net/~crxpower/Audio.wma
I just changed the transmission fluid, and I did not notice anything unusual. I always use GM syncromesh.
Old Apr 12, 2006 | 07:47 AM
tommyj's Avatar
Default Re: Do I have a bad Differential? b16 tranny help (tommyj)
ttt
Old Apr 12, 2006 | 08:39 AM
ZacCarter's Avatar
Sounds like an axel, the diff. if bad would probably not allow the car to go at all.
Old Apr 12, 2006 | 08:52 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (ZacCarter)
something must be wrong with my computer. i didn't hear a thing.
Old Apr 12, 2006 | 09:13 AM
tommyj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like an axel, the diff. if bad would probably not allow the car to go at all.</TD></TR></TABLE>
So Both axles might be bad? Because it makes the noise on both sides.
Old Apr 12, 2006 | 09:15 AM
ZacCarter's Avatar
It could be your intermediate shaft.
Old Apr 12, 2006 | 09:16 AM
tommyj's Avatar
i actually hear the noise coming right from the tranny.
Old Apr 12, 2006 | 09:23 AM
Metalluthier's Avatar
Default Re: (tommyj)
Well, that's hard to diagnose. I don't think it's your differential, sounds like something internal may have snapped or fallen off...I can't say what it is, though if you're shifting fine you can cross off the differential and gear theories. Possibly one of the bearings in your transmission is bad. Could also be a throw bearing
Old Apr 12, 2006 | 09:50 AM
tommyj's Avatar
Default Re: (Metalluthier)
differential bearings?
Old Apr 12, 2006 | 09:54 AM
ZacCarter's Avatar
It's possible, is the tranny stock?
Old Apr 12, 2006 | 10:07 AM
tommyj's Avatar
stock, yes. So is my motor.
eg613
Transmission & Drivetrain
Feb 23, 2009 12:51 PM
xlusiveracer
Feb 25, 2007 09:01 PM
tommyj
Apr 12, 2006 12:10 PM
EK45VTi
Oct 12, 2004 10:58 AM
b16crx1
May 22, 2004 02:03 PM
