Hasport mounts?
Old Apr 11, 2006 | 08:21 PM
atmosphere's Avatar
Default Hasport mounts?
Im doing a 99 jdm b18 gsr swap into my 97 civic hx coupe.
i need 99-00 si rear tranny mount, and driver side mount/bracket. not sure if its need mount or bracket?
and 96-97 del sol AC bracket.
and i can use my stock motor mounts and bushings for the rest of the swap.
Now the question be. What are the benefits of getting the hasport motor mount kit for $455? Will it be a smoother ride? Is it better for motor? just any amount of info can help me out?
Old Apr 11, 2006 | 08:27 PM
BlueIntegraBoy's Avatar
Default Re: Hasport mounts? (atmosphere)
There will be less movement of the engine with the hasport kit. Thus having more in cabin vibrations.
Old Apr 11, 2006 | 08:45 PM
atmosphere's Avatar
Default Re: Hasport mounts? (BlueIntegraBoy)
so the hasport mount will make the inside of my car vibrate more rather than using the stock setup i mentioned above?
Old Apr 11, 2006 | 08:48 PM
Out of every
okay easier to understand
poly urethane inserts and hasport mounts = alot of vibrations in car and i do mean alot. like review mirror is shaking
stock mounts = smooth no vibrations (miss that feeling)
representing inserts
Old Apr 11, 2006 | 09:24 PM
jdm_ekcivic's Avatar
I'd recommend the Hasport kit. I have a Hasport rear mount because my stock mount was fucked up. It vibrates more, but I've gotten used to it by now.
Old Apr 11, 2006 | 10:15 PM
kaoss_11's Avatar
B A N N E D
They vibrate way to much.
Old Apr 11, 2006 | 10:34 PM
Gump's Avatar
Default Re: (kaoss_11)
Just finished installing my Hasport mounts in my 00 Si, I have the street mounts and the only time they vibrate bad is at start up, when the motor is warmed up and idling on the streets the vibration is minimal, not bad at all.
Old Apr 11, 2006 | 10:47 PM
atmosphere's Avatar
Default Re: (Gump)
ok thanks guys. im gonna stick with the si and stock mounts. i want a smooth ride. thanks to everyone.
Old Apr 12, 2006 | 12:50 AM
_Bug_'s Avatar
Default Re: (atmosphere)
Yeah my hasports vibrate but not too bad, its tolerable. And if you need, I got that rear mount. Let me know
Old Apr 12, 2006 | 11:20 AM
atmosphere's Avatar
Default Re: (JDM_Bug)
you have the rear tranny mount from a 99-00 si? if so i want it.
email Ferby13@Hotmail.com
aim : roaan13
Old Apr 12, 2006 | 11:49 AM
Top-Fuel's Avatar
If you were wondering if you needed the bracket or mounts? its actually the brackets because I'm doing a B-series swap this month as well and the guy at honda dealership told me "its the bracket you want not the mount, there's a difference".
Here is also a link to read up on the mounts which I found really useful.
https://honda-tech.com/zero...84137
Old Apr 12, 2006 | 12:01 PM
bow tie's Avatar
Default Re: Hasport mounts? (Top-Fuel)
i'm...feeling good vibrations. i had some bolts on the valvecover and they all rumbled off. it seems to me like only the driver side mount vibrates, when i push down on it, the vibration stops. they're nice, i heard they stop wheel hop also.
Old Apr 12, 2006 | 12:49 PM
atmosphere's Avatar
so i need brackets for both the rear tranny and driver side? or just the driver side bracket?
confused me their?
i need rear tranny mount...and driver side bracket? correct?
Old Apr 12, 2006 | 09:19 PM
_Bug_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere &raquo;</TD></TR><TR><TD CLASS="quote">
i need rear tranny mount...and driver side bracket? correct? </TD></TR></TABLE>
Wait, whats a rear tranny mount? You must mean the rear mount (The one under the i/m)? Or are you talking about the actual tranny mount?
Old Oct 5, 2025 | 05:01 AM
Rshaw410jdm's Avatar
I have a system in my car was told the hasport mounts I'm about to install would cause a lot of vibration and I'm like I have two competition skar 12s in my car with a 2500 watt amp I'm used to vibration 😆
Old Oct 7, 2025 | 03:53 PM
sivicman's Avatar
Have you looked into Hardrace? Better than stock without the vibration.
Vagitarian
Oct 16, 2013 01:49 AM
96b18c-r
Suspension & Brakes
Apr 17, 2009 08:30 PM
92CiviC4dr
Mar 2, 2006 08:04 AM
M.K.C.
Dec 9, 2003 03:40 PM
solman74
Sep 21, 2003 11:52 AM
