Rotten Egg Smell = Catalytic Convertor gone bad ?
Old Apr 11, 2006 | 07:53 PM
Rob.'s Avatar
Default Rotten Egg Smell = Catalytic Convertor gone bad ?
I'm getting a bad smell of eggs or sulfur for a while now on my crx.
My car burns a lil oil.
My car has a new O2 sensor in 2004.
My car fails emissions in 2006.
What could it be ? could it be a bad cat ?
Should I remove it ?
Old Apr 11, 2006 | 07:57 PM
Tippyman's Avatar
Does it happen when your getting on the gas a little harder? If so, probably...
Old Apr 11, 2006 | 07:58 PM
Rob.'s Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Does it happen when your getting on the gas a little harder? If so, probably...</TD></TR></TABLE>
holy shiit ! exactly ! How did you know this ?
Old Apr 11, 2006 | 08:03 PM
crxnj's Avatar
Default Re: (Rob.)
Yeah, bad catylist converters smell like rotten eggs..
Old Apr 11, 2006 | 08:10 PM
StevenTran305's Avatar
Default Re: Rotten Egg Smell = Catalytic Convertor gone bad ? (Rob.)
I have the same problem. Its the smell from the oil burning inside your combustion chamber. I have a New CAT with an old o2 sensor.
Old Apr 11, 2006 | 08:12 PM
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, bad catylist converters smell like rotten eggs..</TD></TR></TABLE>
But you're right too, bad CAT converter smells too.
Old Apr 11, 2006 | 08:40 PM
rayzian's Avatar
Default Re: (StevenTran305)
I have this same problem, but only if I go full throttle will it start to smell. I had my whole exhaust changed (from after the cat) and I looked inside of the CAT and it still looked good?
Old Apr 11, 2006 | 09:29 PM
StorminMatt's Avatar
It's actually not the cat that's really at fault. Rather, this smell results from running a rich mixture and/or trying to burn out oil that has entered the cylinders. Remember that petroleum products contain sulfur. And this is what the cat does with that sulfur when there is too much of it. The smell intensifies if you floor the throttle because the ECU enrichens the mixture further when you do so. But regardless, this smell doesn't mean that the cat is necessarily bad. But it means the cat could go bad soon if the underlying problem is not remedied.
Old Apr 12, 2006 | 06:31 AM
Rob.'s Avatar
Default Re: (StorminMatt)
Its time for a new engine.
LoL
sac ped
Nov 18, 2007 04:46 PM
92 civic VX B18c
Dec 4, 2004 05:46 PM
DIP_SET FoReVr
Nov 27, 2004 06:50 AM
toronto_lude_98
Oct 29, 2004 01:48 AM
WickidSi
10
Apr 30, 2004 06:11 PM
