HELP on LS swap into Civic EX coupe
ok so im doing a LS swap into my 00 civic ex coupe and now im stuck.. the ls motor is a 96 but i change everything to OBD2 already.. i thought i could use my EX wiring harness but it seems that i cannot get the distrb. plug to fit with my wiring harness? Are the wiring harness from an OBD2 car all the same regardless of sohc or dohc?? i need help on this quick.. TIA..
The distributor plug should fit if they are both obd2 dizzys. If your dizzy is the 2 plug one then you know you have the obd1 dizzy.
You can convert your "LS distributor" plugs to a one plug. Then it will work. All the wires are the same. If not, then you will need to get a 97 and above LS distributor.
ohsnapzafingcu
21
Nov 12, 2008 02:22 PM
Vadian
Feb 2, 2002 07:58 PM
