wah wah idle, any info?
Old Apr 11, 2006 | 06:10 PM
94hatchvx's Avatar
Default wah wah idle, any info?
i have a b16sir2 swapped into a 1992 cx hatch back. whenever it warms up it will go wah wah wah every second at a consistant speed from around 1000 rpm to 1500. does anyone know how to fix this. another question. once you have thrown a code and got it fixed how do you reset your ecu?
Old Apr 11, 2006 | 06:26 PM
civicsi_guy's Avatar
check your iac valve or your temp sensors to clear the code (if you fixed it) you can disconnect the battery for like 3 min or pull the ecu fuse for 3 min
Old Apr 11, 2006 | 06:56 PM
intevic_dx's Avatar
check the map sensor and vac lines going to it also.
4g4dcruisin
17
Mar 18, 2010 08:49 AM
kkitz967
Dec 6, 2007 08:34 AM
god.loves.ugly
Jul 27, 2005 07:32 PM
GSRwBOOST
Jul 12, 2001 06:07 AM
