a/c and p/s removal
Old Apr 11, 2006 | 01:54 PM
angelSIR-G's Avatar
Default a/c and p/s removal
don't know if i'm just retarded but i can't find any threads on this.
just looking for a guide to make sure i do it perfectly.
Old Apr 11, 2006 | 02:32 PM
rgaray's Avatar
Click on "Archive content" when searching.
Old Apr 11, 2006 | 05:16 PM
angelSIR-G's Avatar
Default Re: (rgaray)
i did still can't find anything.
i'll try again
Old Apr 11, 2006 | 05:18 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (angelSIR-G)
So you're taking out the p/s also?
The a/c is pretty straightfoward, you don't really need a guide, unless you're taking the stuff out inside too.
Just follow all the lines, and unhook them.
Old Apr 11, 2006 | 05:38 PM
angelSIR-G's Avatar
Default Re: (FlatBlackTeg)
thanks
yeah the p/s too
Old Apr 11, 2006 | 05:43 PM
Hype-R Stalker
The p/s is going to be a little more difficult,
it's not just disconnect everything, and with the engine in, it'll be a lil bit more maneuvering.
But it's not actually all that bad .. I did mine though with my engine out
I can get some pics of how mine is setup tomorrow though,
You don't need to buy any special p/s delete kit, just some hosing.
You might want a different resivoir though, the stock one is a bit overkill/big.
Old Apr 11, 2006 | 05:45 PM
SlamminS85's Avatar
just remove the belt... that will turn off your ps, and you can alwasy put it back on... unless you are removing it for weight issues
Old Apr 11, 2006 | 05:51 PM
Hype-R Stalker
Default Re: (SlamminS85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">just remove the belt... that will turn off your ps, and you can alwasy put it back on... unless you are removing it for weight issues</TD></TR></TABLE>
Lol, well if they're removing the a/c, it's probably for hp, And weight.
Old Apr 11, 2006 | 06:01 PM
angelSIR-G's Avatar
my motor is out currently which will make it easier
plz post those pics when you get a chance
Old Apr 11, 2006 | 06:12 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angelSIR-G &raquo;</TD></TR><TR><TD CLASS="quote">my motor is out currently which will make it easier
plz post those pics when you get a chance</TD></TR></TABLE>
ahh well you're in luck then haha, I'll get some up tomorrow when it's light out.
I can tell you right now though, there is Only two fittings coming off the rack,
all you do it loop those two to a reservoir.
You can even use the fittings on there, you just have to do a little "modding" to the one I think.
Old Apr 14, 2006 | 04:29 AM
angelSIR-G's Avatar
got those pics
Old Apr 14, 2006 | 08:00 AM
Hype-R Stalker
sent them via pm
Old Apr 14, 2006 | 09:03 AM
. x A t t a c k's Avatar
I don't know if Padawan still sells his p/s removal kit, because his thread got shut down. You're going to need to rig up a close loop system that would be recirculating the ps fluid in the system. Or else its going to get seized.
https://honda-tech.com/zerothread?id=184202
https://honda-tech.com/zerothread?id=462824
https://honda-tech.com/zerothread?id=563114
JDMkidGSR
Dec 15, 2008 02:45 AM
janz3n
60
Jul 27, 2007 02:55 AM
Hybrid2Be
Dec 14, 2003 08:50 AM
Nacho169
Sep 29, 2002 09:36 AM
