Failed Emissions testing (running rich) What should I do now?
Old Apr 11, 2006 | 11:13 AM
Maxximtl's Avatar
Default Failed Emissions testing (running rich) What should I do now?
I have been battling my 90 si with a b16a swap for a month now. I just redid the wiring relating to the oxygen sensors using a rywire harness. The car still has a partial throttle hesitation problem which I believe is linked to the rich running condition.
I only have 10 days in order to fix the problem, so I need to get this figured out fast. What should my next step be in diagnosing this problem? Should I go ahead and replace the o2 sensors, or is there something else I should look at first?
Old Apr 11, 2006 | 05:31 PM
W O T's Avatar
Default Re: Failed Emissions testing (running rich) What should I do now? (Maxximtl)
How high over were you exactly?
When I was about 15% over the limit with the Co's I simply changed my air filter, oil, added fuel injector cleaner and 94 octane
I also added about 1/2 liter of 99% rubbing alcohol and she passed no problem at all
Need more info though, how bad your failing by and on the idle test or the rolling
Knowing your setup/timing/recent changes would save some time
Old Apr 11, 2006 | 08:01 PM
Maxximtl's Avatar
Default Re: Failed Emissions testing (W O T)
My CO was over twice the allowable limit. This was on a rolling dyno.
The car is still getting 25+ mpg, so the car can't be running THAT rich. The car seems to be fine from a tune perspective...although I haven't had an opportunity to verify the timing. I run 91 octane in it (premium here in denver.)
Any suggestions would be appreciated.
noob2006
Jun 22, 2006 03:56 AM
90jdmcrxdude
May 25, 2006 07:49 PM
blackmagicCRX
Oct 17, 2005 05:23 PM
thecivicking
Jun 2, 2003 06:06 AM
1990CrxSi
Nov 22, 2002 11:43 PM
