Please help with "Charge System Warning Light".
Old Apr 11, 2006 | 10:09 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Please help with "Charge System Warning Light".
My stock 89 CRX Si has been having the charge system warning light come on at idle.
My observation from driving w/ a volt-meter on the battery:
It seems that as soon as the ECU swtches the alternator into "low-voltage" charge mode (to save gas), the idiot light comes on. The light stays on until the voltage finally drops down to 12.5v. Then the voltage settles around 12.3v. The light ALWAYS goes out when I rev the engine, but the voltage never changes. Voltage always jumps back to 14+ when I hit 45mph (like it should).
Here is my attempts to resolve the problem (with no results):
I've tried 3 different alternators (1 old & two remand autozone units), and two different under-hood fues boxes (ELD is built into fuse box). All wiring & belt tension checks out...
Does anybody know what the hell could be going on?
Old Apr 11, 2006 | 12:03 PM
Tyson's Avatar
Default Re: Please help with "Charge System Warning Light". (94eg!)
you got me stumped...
clean connectors and ground?
tried a different ecu?
Old Apr 11, 2006 | 12:34 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Please help with "Charge System Warning Light". (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you got me stumped...
tried a different ecu?</TD></TR></TABLE>
I havn't personally cleaned the grounds, but my mechanic checked all the wiring. They are good guys too (worked on the car for 2 days & didn't charge me since they couldn't fix it).
Well, the only thing left to do is try a different ECU. I don't know anybody with a PM6, and my mechanic's one was fried by another customer's moded car...
Anybody here in Vegas with a CRX Si that wouldn't mind taking an hour or so to help me out (swap ECU)?
Old Apr 11, 2006 | 09:58 PM
mr_hahn73's Avatar
Definately check the grounds and and terminal connections. Had the same problem and I solved it with those to things being checked and fixed.
Old Apr 11, 2006 | 10:11 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Please help with "Charge System Warning Light". (mr_hahn73)
Does anybody know how to pull the pins out of the Alternator harness plug?
I think it would be 1000 times easier to check for problems if I could check each crimp & connector...
Old Aug 27, 2011 | 06:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
Back from the dead!!!
This problem turned out to be two crappy alternators from Checker (Now O'Reilly's) Auto Parts. I guess both the ones I tried from there were crap. I honestly think it may have had the wrong size pulley on it or something. The one I had been running for all these years finally took a dump. Happened just hours before I was taking it on a trip outta town (lucky I guess). It left me in the middle of a busy intersection in 105* Las Vegas weather.
Well after I called for a ride, picked up some tools, picked up a new lifetime warranty alternator from Autozone, and changed it out in the parking lot of the gas station..........PROBLEM SOLVED!!!! It's been a couple months and the charge warning light hasn't come on once.
Old Aug 27, 2011 | 06:22 PM
Tyson's Avatar
funny, 5 years of experience on this forum has taught me that no matter how many "new" alternators you get, its always possible you got a bunk one from the parts store.
i was a little confused i gave that answer when i read it. then i saw the date...
Old Aug 27, 2011 | 07:18 PM
94eg!'s Avatar
#1 Super Guy
Loved
You 'da man Tyson...
ogawa_jiei
Nov 11, 2006 12:43 PM
O16581724 5 2 5
10
Jun 30, 2006 04:40 PM
Touge Tuning
Mar 3, 2006 06:29 PM
mntdewred
Nov 18, 2003 05:10 PM
ck279
Sep 29, 2001 10:32 AM
