Are either of the front axle nuts reverse threaded?
Old Apr 11, 2006 | 08:10 AM
professor poon's Avatar
Default Are either of the front axle nuts reverse threaded?
If so, which one or both? I can't see the threads, so if anyone knows I appreciate the help in advance.
Old Apr 11, 2006 | 08:15 AM
Luserkid's Avatar
Default Re: Are either of the front axle nuts reverse threaded? (professor poon)
The only nuts that i know of thats reverse thread is on the power steering pully and i think alternator pully as well.
Everything else is normal lefty loosy, righty tighty
Old Apr 11, 2006 | 08:17 AM
Slopoke's Avatar
Yep, they're both normal threads.
Old Apr 11, 2006 | 08:31 AM
I guess I just need to eat some spinach before attempting them again
Old Apr 11, 2006 | 08:35 AM
v4lu3s's Avatar
RTFM
Default Re: Are either of the front axle nuts reverse threaded? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The only nuts that i know of thats reverse thread is on the power steering pully and i think alternator pully as well.
Everything else is normal lefty loosy, righty tighty </TD></TR></TABLE>
unless you got some sort of weird honda then those are not reverse threaded either.
and it takes a lot of power to get the axle nuts off, i usually use an impact gun tht is capable of 450lb/ft though at times I have had to go with a bigger gun as well.
Old Apr 11, 2006 | 09:55 AM
Default Re: Are either of the front axle nuts reverse threaded? (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">unless you got some sort of weird honda then those are not reverse threaded either.
and it takes a lot of power to get the axle nuts off, i usually use an impact gun tht is capable of 450lb/ft though at times I have had to go with a bigger gun as well.</TD></TR></TABLE>
I was jumpin on a 2-3ft. breaker bar and I'm about 155, so apparently &gt;350lb/ft doesnt cut it... this is sooooo frustrating.
Old Apr 11, 2006 | 10:24 AM
v4lu3s's Avatar
RTFM
somestimes that much wotn cut it, i have had ot use a 6 foot piece of pipea nd several breaker bars....cause they kept breaking on me.
Old Apr 11, 2006 | 10:38 AM
ITS_Dunn's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">somestimes that much wotn cut it, i have had ot use a 6 foot piece of pipea nd several breaker bars....cause they kept breaking on me.</TD></TR></TABLE>
get someone to keep the brakes on, get a breaker bar with a 3 ft peice of pipe on it (harder pipe the better, i always broke my pipe) and get a hammer and crack on it hard and quick if you cant do it with your weight. cut the wheels away from the car too
Old Apr 11, 2006 | 10:40 AM
ITS_Dunn's Avatar
Default Re: (Dunn)
as for reverse threaded, i think you will find that on older toyotas or even old old hondas (so ive heard, not sure about hondas) - quite a few of the older domestic cars are reverse, most cars now are the right thread now.
Old Apr 11, 2006 | 10:59 AM
I'll just have my mom step on the brake, then have my cousin (who's car this is) AND me stand on the 5 ft pole that we just bought. maybe 1500lb/ft will do the trick... But then again at that point his brakes prolly won't hold.
Old Apr 11, 2006 | 11:00 AM
Default Re: (professor poon)
weird thing is that the other side was only like 275lb/ft or so
Old Apr 11, 2006 | 03:08 PM
thanks everyone...we got that little ****** off with about 750 lb/ft.
Old Apr 11, 2006 | 07:05 PM
NJcoupe's Avatar
And the Final drive bolts.
Old Nov 19, 2025 | 04:11 PM
The_Carr's Avatar
I just broke two Breaker Bars and haven't gotten mine loose, yet... I don't think Spinach is gonna Cut It 😅
Old Nov 19, 2025 | 04:14 PM
theYBLEGAL's Avatar
Loved
Heat, penetrating oil, and vibration will do it. Repeat until free. MAP gas or propane will work, acetylene if you got it. Impact gun.
Old Nov 19, 2025 | 05:21 PM
Grade50's Avatar
10 Year Member
Seriously, just get one of these and be done with it. Works great for pressing out lower balljoints too...
Fat Chick Magnet
Jan 19, 2008 03:45 PM
MitsukillinS2K
28
Mar 13, 2007 08:31 AM
*Boostwerks*
Suspension & Brakes
Feb 4, 2005 04:37 AM
G2turbo_terror
Nov 26, 2004 09:24 AM
KrashZer0
May 26, 2002 02:47 PM
