Problem Turbo CRX
Old Apr 11, 2006 | 03:51 AM
91backslash's Avatar
Default Problem Turbo CRX
Well guys i sold my CRX and sold my turbo to my buddy, now he is havin a problem with it becuase he partially doesnt know anything about turbo or workin on the car so im buying his car off of him. he has a d16a6 with a t3 super 60 all stock motor not running more than 8 psi. the problem he is having is the car will not go over 3400ish RPM's which is leaving me thinkin that it is the fuel injectors because they will limit the rpms. and the plugs are fouling themselves out after each drive. and he has an SAFC hack but he took it off. would you guys say that all that should be wrong with the car is that the hack needs to be re-installed and pull fuel out get new plugs and it should be running fine?
Old Apr 11, 2006 | 04:08 AM
hm.. just found out there is a stock fuel pump still, hes on a stock si clutch... anyone with suggestions?
Old Apr 11, 2006 | 04:20 AM
Boosted Chemist's Avatar
Default Re: (91backslash)
whats the fuel management?
stock fuel pump is fine for low hp (>300whp)
Old Apr 11, 2006 | 04:36 AM
just the hack for now. will be getting it tuned with turboedit in about a month.
Old Apr 11, 2006 | 04:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91backslash &raquo;</TD></TR><TR><TD CLASS="quote">just the hack for now. will be getting it tuned with turboedit in about a month.</TD></TR></TABLE>
stock ecu? becasue i bad chip/ecu may cause an car to have a low rev limit.
does it have 450s?
Old Apr 11, 2006 | 05:05 AM
yea its a stock one. and yea they are 450's ill check to make sure its still throwing CEL codes for fuel injectors
Old Apr 12, 2006 | 06:33 PM
the ecu's red light stays on solid, whats goin on?
Old Apr 12, 2006 | 06:37 PM
Sikocivic's Avatar
You need something(the Hack or Turboedit) to control the 450 injecters. I am shocked that the car even runs with them in there and a stock ECU.
Solid red light means the ECU is bad.
Old Apr 12, 2006 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91backslash &raquo;</TD></TR><TR><TD CLASS="quote">the ecu's red light stays on solid, whats goin on?</TD></TR></TABLE>
bad ecu or bad chip
Old Apr 12, 2006 | 07:19 PM
beyondspexj's Avatar
yup something messed up the ecu. when your buddy took the safc out did he take the wires back off and resoldered them good or was it a yank and half *** uninstall?
Old Apr 13, 2006 | 03:50 AM
im not to sure on the uninstall but i will be reinstalling the hack this weekend to see if i can atleast get it to pull fuel. it has a JUN chip in it which isnt for sohc i've been told so that is the problem im guessing, do you think im gonna need a whole new chip, im also getting it tuned with turbo-edit so are they just gonna replace they're chip where the JUN chip is?
Old Apr 13, 2006 | 04:57 PM
yea if your going to get turboedit i wouldnt bother putting the hack back in. and yes it is going to replace that chip you have in there
rexthermal1
Oct 9, 2005 12:00 PM
HybridTeg
Oct 22, 2004 09:46 AM
J.P. 4rm The dPk*
Sep 26, 2004 12:07 AM
gcajnr2121
Mar 12, 2003 11:24 PM
UNDER PRESSURE
10
Jan 16, 2003 10:41 AM
