Smc+
Old Mar 4, 2003 | 09:42 AM
gcajnr2121's Avatar
Default Smc+
i have a d15b7 stock(92-95 civic), just installed turbo, 450dsm injectors w/10w 10ohm res. inline. wired up the smc+ and it idles smooth, but when i give it gas, it floods out and almost dies. it is set at -59 @ evry rpm, plugs are black and a/f led is in the green. what could my problem be? i'm so frustrated.
the smc+ is wired right and the green light blinks when car is running.
Old Mar 4, 2003 | 09:52 AM
baphomet's Avatar
Default Re: Smc+ (gcajnr2121)
I'm no expert, but maybe your fuel pressure is to high - I read that someone had a problem not being able to cut enough fuel with the smc and lowering the fuel presure fixed it - just a thought. Btw, what other, if any, fuel mods do you have?
Old Mar 4, 2003 | 10:03 AM
MikeMAN's Avatar
just remember, don't lean it too much! that will cause a problem also! remember u are taking OUT 59% of your fuel. leaving you around 180cc, which is 60 smaller than stock. so u need MORE fuel.
mike
any problems, just pm me start with -35 across the board
Old Mar 4, 2003 | 10:35 AM
gcajnr2121's Avatar
Default Re: Smc+ (MikeMAN)
hey i dont have permission to im yet But i did start at -35 and it was super rich. that is why i went to -59 just see if it made a difference. I'm running gsr fuel pump and stock fpr.
Old Mar 4, 2003 | 10:38 AM
MikeMAN's Avatar
super rich by what? the autometer? just by stepping on the gas?
dont do tuning with the autometer, very innacurate, forget you have it when u are using ur SMC
mike
Old Mar 4, 2003 | 10:47 AM
gcajnr2121's Avatar
i could put a b&m fpr and lower the fuel pressure Post your thoughts
Old Mar 4, 2003 | 10:49 AM
gcajnr2121's Avatar
super rich by stepping on gas, black smoke comes out, plugs are black, autometer stays in the green
Old Mar 4, 2003 | 11:18 AM
baphomet's Avatar
If your sure that your really rich, it makes sense to me to lower your fuel pressure, just don't cut as much with the smc afterwards, try to get the fuel pressure at a point where you can actually use the smc to fine tune things.
Old Mar 4, 2003 | 11:56 AM
gcajnr2121's Avatar
Default Re: Smc+ (b3435)
well i will try the b&m fpr and lower the presure but it should run on my stock fpr. Whats the freakin deal is it my car or the smc+, I wish i understood more about how the smc accually works, and my car.
Old Mar 4, 2003 | 12:20 PM
baphomet's Avatar
yeah it should run off the stock fuel pressure - hope you get it working, I'll be installing one soon so let me know how it goes
Old Mar 4, 2003 | 02:34 PM
MikeMAN's Avatar
if it doesn't stutter much, i would rather be rich, than run lean and blow it
mike
Old Mar 5, 2003 | 07:10 PM
gcajnr2121's Avatar
i'm not sure what to think about the smc cause i had to lower my fuel pressure to like 21psi to allow my car to be drivable with the dsm injecters and it is still to rich and my car bogs down. , and i also got a code 43 later on cause my dumb fp is too low. what is the deal here? the smc seems to be working cause its blinking. Maybe i need to just tweak it more to see if it will run better. It should run with the stock fuel pressures!
Could the dsm injectors be messing up. but i got them off my bro. t-eclipse and one or two had cracked plastic end peices, but i plan on replacing w/ new caps and i did not think that it would cause my car to run this bad, they ran fine on his eclipse.
setting for smc+: idle:30, 1-8:40
Mikeman: it does'nt bother me to run rich i'm not a FOOL but my car would not GOOOOOOO when i depressed the pedal, it would bogg out rich and Die or in other words my car had to be pushed if i wanted it to move a foot. Do you understand? today i turned down fuel pressure and it moved down the road fairly but would still bogg down rich and poop black dump all over my cockplugs when i tried to gas it.
If anyone can help me solve this problem or know anyone in OKLAHOMA CITY that knows fart about anything just let me know. Thanks yall
Old Mar 5, 2003 | 07:12 PM
MikeMAN's Avatar
never said u were a fool, just simply trying to help you with your problem...because im not the one who's having trouble getting the smc to work
mike
Old Mar 5, 2003 | 07:41 PM
gcajnr2121's Avatar
it was just a statement
Please post if ya know How to help me. have had the same problem or know how to fix problem or just tell me im a prickface thanks
Old Mar 5, 2003 | 07:47 PM
MikeMAN's Avatar
you're a prickface..
okay, have u tried literally all the settings for idle? and double check ur connections, soldering is the only way to go!
i have lots of experience with the SMC, its my best friend!
mike
pm me and i can help ya more in depth and faster responses!
Old Mar 5, 2003 | 07:48 PM
MikeMAN's Avatar
nevermind...i don't think u can PM as a trial user...
Old Mar 5, 2003 | 08:07 PM
gcajnr2121's Avatar
im going to try to fix the injecters tommorrow(plastic ends by the sprayers) and see if it mixes the fuel better with the air. How long did it take for you to get your car running right, and why did i throw a code 3 @ only 4lbs boost? My car idles fine, its what happens after idle.
I can only post 5 times per 24hr period.bullcrap!! I was under the name gcajnr21 and i forgot my password i guess, and my e-mail has changed so they wont send my password to my new address, I AM A Member here 100%, but the ****** who run this joint can't seem to fine the grace to help somebody out I have e-mailed then like 4 times know in the last month and still no response. now i'm a honda-tech Kid with a bed time and can't even wash my own crack or reply to my own post. Oh-well
Old Mar 5, 2003 | 08:13 PM
MikeMAN's Avatar
to be honest, my idle was perfect out of the box as soon as I hooked up the SMC. I would check your resistors on ur injectors.
mike
Old Mar 5, 2003 | 08:23 PM
gcajnr2121's Avatar
my resistors are freshly sodered in line w/each injector y/b wires + 4 10w/10ohm from rshack. I soder all my connections and put shrink wrap around them, I like to do thinks the right way.
maybe i should just take a sledge hammer and sledge my whole car and the smc+ and my motor and my face, maybe it would turn out perfect and i could stick my fat Log in the exhaust pipe and start my car and boost my brain off.
Old Mar 6, 2003 | 07:22 AM
gcajnr2121's Avatar
does anyone think it could be the injectors?
Old Mar 6, 2003 | 07:30 AM
Jason kiDD's Avatar
Yes. They probably arent flowing right and having the crack on the caps is probably not helping much. Also make sure that your map signal is correct and that all GROUND wires are properly grounded.
Old Mar 6, 2003 | 07:54 AM
MikeMAN's Avatar
Default Re: Smc+ (Jason kiDD)
probably has nothing to do with the injectors, the pintle caps are simply there for protection. as long as your removed the whole cap, im sure ur okay. (one of mine had a cracked cap, so I just broke it off)
mike
Old Mar 6, 2003 | 02:50 PM
baphomet's Avatar
man...before you do all that can I have your parts?
Damn, I wish I could help, seems like your really stressed. Try swapping EVERYTHING with known good ones.
UP. Maybe someone else can offer a suggestion.
Old Mar 6, 2003 | 08:31 PM
gcajnr2121's Avatar
I figured it out!!!! i had it wired wrong, I'm a freakin ***** face who needs to have my anus air-chiseld. make sure you dont let your brain wire stuff up wrong GET PLENTY OF SLEEP BEFORE INSTALL(that should be in the instructions 1st step)
Well my car is pullin great and runnin so so smooth just needs to be dynoed for a perfect tune for that days barometric reading.
Now have stock fp and dsm 450's set in the -30's range. AWESOME!!!!!
FMU's suck SMC+
Old Mar 6, 2003 | 08:40 PM
MikeMAN's Avatar
FMU's suck SMC+
glad u figured it out ***** face (*cough...wiring*)
