Threw A Cel 45....
Old Apr 11, 2006 | 01:00 AM
kidd_drastic's Avatar
Default Threw A Cel 45....
Well i have a gsr head on a itr bottom end. it has a fpr and gauge. When i try to accelerate the engine lags and the rpms go up slow. I threw CEL 45 today. I means i am running to lean or too rich. i'm assuming its lean because the engine struggles and doesn't backfire. Any ideas on how to fix this?
Old Apr 11, 2006 | 01:13 AM
fmrprojects's Avatar
Default Re: Threw A Cel 45.... (kidd_drastic)
check your fuel system there might be a leak somewhere. obd-2 has all kinds of extra sensors. it might be a bad evap system, loose fuel cap. bad fuel cap, evap system doesnt hold vacumm
Old Apr 11, 2006 | 01:34 AM
Default Re: Threw A Cel 45.... (fmrprojects)
so many things. anymore input?
Old Apr 11, 2006 | 10:39 AM
bump
Old Apr 11, 2006 | 02:20 PM
woot
Old Apr 11, 2006 | 06:18 PM
does anyone know the stock fuel pressure for a b18 gsr/type r
Old Apr 13, 2006 | 12:13 AM
bump
Old Apr 13, 2006 | 01:30 AM
strictly.business's Avatar
Banned
if you have an fpr, adjust it in small incroments until it runs better. its best to dyno tune it.
Old Apr 13, 2006 | 08:25 AM
Default Re: (strictly.business)
yeah i raised the fuel pressure it 48. runs much better. the cel still turned on though. hopefully i can put it on wideband to see what is wrong.
Old Apr 13, 2006 | 10:16 AM
honda head's Avatar
Default Re: (kidd_drastic)
it might be your o2
Old Apr 13, 2006 | 11:28 AM
Default Re: (honda head)
hmm my idle sometimes floats aboe the 1000 rpm range. could a vacuum leak cause this?
Old Apr 13, 2006 | 06:34 PM
honda head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic &raquo;</TD></TR><TR><TD CLASS="quote">hmm my idle sometimes floats aboe the 1000 rpm range. could a vacuum leak cause this?</TD></TR></TABLE>
yeah, that could be it
Old Apr 15, 2006 | 09:43 AM
i ran a OBDII scanner and it says i'm running lean. i turned the fuel pressure up to about 50. any suggestions?
Old Apr 22, 2006 | 10:18 PM
Old Apr 22, 2006 | 10:24 PM
b00sted_hatch's Avatar
Little Hercules
CEL 45 is running to rich/lean it might be your injectors..are they pinching??
Old Apr 22, 2006 | 10:30 PM
Default Re: (b00sted_hatch)
it says i'm running lean on a obdII scanner. what does pinching mean?
Old Apr 23, 2006 | 09:36 AM
Little Hercules
its when your injectors doesnt squirt as much fuel as they usually are squirting..correct me if im wrong honda-tech
Old Apr 23, 2006 | 05:40 PM
jdeemseerx's Avatar
check your dizzy timing, being retarded or too far advanced will mess with your mixture
Lifter2012
Jan 23, 2006 04:10 AM
2000CX
Aug 14, 2003 05:15 PM
degooser
12
Apr 23, 2003 05:16 AM
