SOHC Revving Help Please!!
Old Apr 10, 2006 | 10:34 PM
89eFRACER's Avatar
Default SOHC VTEC Revving Help Please!!
iI JUST SWAPED MY 89 STD OVER TO A 95 D15Z1 VTEC-E I BOUGHT IT FROM A FRIEND I DROVE THE ENGINE BEFORE I BOUGHT IT, BECAUSE IT WAS IN A FRIENDS 91 SI. BUT I SWAPED EVERYTHING PERFECT AND THE ENGINE STARTS BUT IT WILL NOT REVV UP IM THINKING IT'S SOMETHING WITH THE WIRING DOES ANYONE KNO WHAT COULD BE THE PROBLEM ON WHY IT'S NOT REVVIN
CAN SOME ONE THROW ME SOME IDEAS ON WHAT CENSORS THAT COULD BE UN PLUGGED OR VACCUM LINES, ALSO WE CHECKED THE TIMING AND MY INTAKE MANIFOLD IS SUCKING WIND GOOD AND MY HEADERS ARE THROWING OUT GOOD WIND AND EVERY THING IT'S NOT EVEN SMOKING; IT'S JUST NOT REVVIN
Old Apr 10, 2006 | 10:39 PM
1989CivicSi's Avatar
Default Re: SOHC VTEC Revving Help Please!! (89eFRACER)
Throttle cable?
If it's not that, does it just bog out when you try to rev?
Old Apr 10, 2006 | 10:42 PM
SD_Lurker's Avatar
HT White Ops
most you yell?? there any specific reason you are writing in caps?? do you think that its going to get you help any faster?
i think some more details would definetely help us aid you in fixing the problem. just simply stating that its not reving could be serveral things. what are the characteristics?
Old Apr 11, 2006 | 09:12 AM
89eFRACER's Avatar
yea i checked the throttle and its okay, but when i rev it, it just goes to like 3,000 rpm and then it acts as if it want's to turn off then it just idles fine. Would the distributer not allow it to rev if it is not wired right. I checked all the wires and injectors are spraying and everything. I checked the computer in my friends obd0 Integra and it revs fine. What censors would make it not rev.
Old Apr 11, 2006 | 11:23 AM
Tippyman's Avatar
TPS? Did you switch the wies on the tps sensor? there are three wires on the tps sensor. switch the outer two wires with each other.
Old Apr 11, 2006 | 09:59 PM
89eFRACER's Avatar
Default Re: (Tippyman)
alright man i'll check that on thursday when i go try to finish my swap.
kings1ey
Apr 28, 2006 12:52 PM
SjCiViCHB
12
Sep 24, 2004 12:57 AM
Shiftquick
Jul 12, 2004 08:33 PM
ThugLife52
Nov 11, 2002 07:43 AM
