regular oil in a b16 ?
would it be bad for the motor to use regular (non synthetic) oil in a b16 ?
what are the negative effects ?
Modified by killaj12 at 10:03 PM 4/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 »</TD></TR><TR><TD CLASS="quote">would it be bad for the motor to use regular oil in a b16 ?
what are the negative effects ? </TD></TR></TABLE>
WTF
WTF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">i think he means non synthetic oil</TD></TR></TABLE>
lol yea, non synthetic
sorry
ive been using sythetic or synthetic blend, but i was wondering if there are any negative effects of using non synthetic oil
sorry
negatory ghost rider. u should be fine. taking into consideration if u are switching back from synthetic due to monetary reasons. if u are switching back due to synthetic causing a leak.. non synthetic oil will not fix it. just make sure to change your oil at the scheduled intervals ex 3000 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">what is regular oil? wall mart oil? just use 10w-30 castrol gtx</TD></TR></TABLE>
honda says use 5w-30 for the B16a2
i heard usign a thicker oil makes vtec kick harder casue of the pressure due to viscosity. i dotn know if its true but it sure felt like it in my boys car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 »</TD></TR><TR><TD CLASS="quote">i was wondering if there are any negative effects of using non synthetic oil</TD></TR></TABLE>
No, as long as you keep it topped off and change it at regular intervals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">i heard usign a thicker oil makes vtec kick harder casue of the pressure due to viscosity.</TD></TR></TABLE>
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen »</TD></TR><TR><TD CLASS="quote">honda says use 5w-30 for the B16a2 </TD></TR></TABLE>
that is what i use as well. i have almost 200k on my 99 si with no issues. i usually run castrol or quaker state regular oil. synthetic is not needed unless you are reaching very high temps or want to wait a bazillion miles before oil changes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">
yep i'm going on 164k without any MAJOR problems..knock on wood
</TD></TR></TABLE>yep i'm going on 164k without any MAJOR problems..knock on wood
99delsol
Oct 22, 2006 06:38 PM
