dsm injectors
Pull out the old ones, drop in the new ones...basically that simple. Might have to widen the plastic O-rings, might not (I had to, but I've seen some people that haven't)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly »</TD></TR><TR><TD CLASS="quote">bore out the seals, then plug and play. also you gotta get a razor and cut a peice of the plastic on the clip off so it plugs in nicely.</TD></TR></TABLE>
how do i bore them out?
^^ that makes no sense.
you have to dremel the lower seal as shown and re-use the DSM seals. don't remove anything. you also have to mod the clip slightly as previously stated. then they'll bolt in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">^^ that makes no sense.
you have to dremel the lower seal as shown and re-use the DSM seals. don't remove anything. you also have to mod the clip slightly as previously stated. then they'll bolt in.</TD></TR></TABLE>
+420!
Nasty arSS Vaccum Leak. Just bore it out to make it fit snug with the injector housings.
Brain
+420!
Brain
94lsboost
Apr 7, 2005 07:07 AM
DsMWookie
Oct 22, 2003 07:05 AM
