D16A6 Block Question
I have currently disassembled my d16a6 engine, i have measured the cylinders and found out that the cylinders are out of round and tapered.
i called a machine shop to ask how much it was to re-bore the cylinders bigger and they recommened simply re-ringing the motor.
I was wondering if this was a better way to do my re-build or if i SHOULD re-bore and get new cylinders. Any info would help greatly, Thanks
If i re-bore i will have to go to .050mm, but the machine shop said that i can simply re-ring..... i don't understand thier logic.
Any info helps
and thanks again
Any info helps
and thanks again
