razor edge cams
Old Apr 10, 2006 | 07:15 PM
Devo94ac's Avatar
Default razor edge cams
ok so i heard about razor edging your camshafts. i heard this will take about 9 lbs off the rotating force. is this true? and has anyone done this and seen actual results in a stock engine? thanks for any responses!!
Old Apr 10, 2006 | 08:31 PM
arrojj's Avatar
Default Re: razor edge cams (Devo94ac)
i dunno but ill consult with my engine builders and my machine shop
Old Apr 10, 2006 | 09:28 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devo94ac &raquo;</TD></TR><TR><TD CLASS="quote">ok so i heard about razor edging your camshafts. i heard this will take about 9 lbs off the rotating force. is this true? and has anyone done this and seen actual results in a stock engine? thanks for any responses!!</TD></TR></TABLE>
I think you are refferring to knife edging your crankshaft. You cannot modfiy cams.
Knife edged cranks, if not done properly, can cause bad harmonics, especially when paired with a light flywheel or non-dampened crank pulley. You may see premature bearing wear.
If you want your crank machined, a good balancing and micropolish is all you need.
Old Apr 11, 2006 | 07:24 PM
Devo94ac's Avatar
Default Re: razor edge cams (92TypeR)
yeah sorry i meant crankshaft i got a little ahead of myself, yeah i know about the premature bearing wear but when this is done, does it really take 9 lbs off? i know it will create more horse power and torque because the shafts are moving faster and cutting through air and oil faster.
chickenwing
Sep 30, 2008 03:31 PM
littlegreenb18
24
Nov 25, 2005 07:59 AM
Green Lude 93
Apr 14, 2005 04:15 PM
BoostedH23Accord
Oct 2, 2004 01:41 AM
miahmouse
Apr 14, 2004 11:09 AM
