Wheel Hop
When I shift at high rpm's my car just starts to shake like crazy and then it tapers off and everything is fine again. It only happens for a few seconds. How can I fix this?? Oh and my suspension is Spoon dampers and springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalVinyl »</TD></TR><TR><TD CLASS="quote">When I shift at high rpm's my car just starts to shake like crazy and then it tapers off and everything is fine again. It only happens for a few seconds. How can I fix this?? Oh and my suspension is Spoon dampers and springs.</TD></TR></TABLE>
Your description doesnt sound like wheel hop.
There is one more option. You can opt for bigger tire/wheel. My 17 inch RO_JA Lt5's with pirelli p zero's weight about the exact same as my stock. They got rid of the wheel hop instantly without changing anything else.
Just another option to think about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">
Your description doesnt sound like wheel hop.</TD></TR></TABLE>
wheel hop is something you'd get in first gear after vtec crossover
Ok well it doesn't really matter what it is thats going on, I'm more concerned with how to fix it. So whatever it is (the shaking), how do I go about fixing it? Putting on my 16" rims (JDM Type-R wheels) it seemed to make things a bit better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalVinyl »</TD></TR><TR><TD CLASS="quote"> Putting on my 16" rims (JDM Type-R wheels) it seemed to make things a bit better.</TD></TR></TABLE>
Told ya Derekkk!
haha
Told ya Derekkk!
haha
That goes against common knowledge about racing.
I have first hand experience that bolting on bigger wheels/tires produce more wheel hop. Remember? I used to have 17" wheels.
Less sidewall means the tire doesn't flex as much. When you're tire doesn't flex, it either spins, or it bounces creating wheel hop.
I also agree that what the original poster is describing is not wheel hop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses »</TD></TR><TR><TD CLASS="quote">To eliminate wheel hop there's a few things you can do:
- Run stiffer springs or dampers
- Run stiffer motor mounts
- Install a traction bar
Also consider an engine torque dampener.....
Is it only 1st to second or second to third as well too? I used to get the same king of bouncing but it would only occur 1st-2nd shift. I will have my jdm 16's on here in about a week, i will let you know if it comes back again after i decrease in rim size from 17 to 16.
yeah don't shift at high rpms, and it'll never happen again
Yea it's essentially from 1st to 2nd. And the comment about not shifting at high RPM's, that doesn't exactly fix the problem; ignoring it won't make it go away
How do I go about "checking" my hubs?
Ok so I've jacked the car up and there is no play at all in the wheel. I took the car for a full inspection from Honda and it said that new spark plugs and a battery was needed so I'm going to replace those today (I just bought the car a week ago). Any other ideas as to what it is?
I drove the car again trying to figure out when it happens and it's at launch, and from 1st to 2nd.
probably caused by your suspension... you can get wheel hop in 1st gear w/ stock suspension.. but i never see anyone do it in second.. you can improve by launching more smooth, don't dump the clutch right away, i'm not sure what can be done about second gear..
Cheapest ($40-$50)and best thing to do is get Energy or Prothane Motor mount inserts. They helped me on the steet and drag strip. They do make the car a little noisier. Good products
i had this wheel hop issue... when i first put my jdm 16's... i had bought brand new toyo t1r's i had this happened when i would hit it hard switching from 1st to 2nd. Now since the tires are broken in... it just peels out
