is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles?
Old Apr 10, 2006 | 03:14 PM
lalaine17's Avatar
Default is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles?
I have a 92 DA and and DB8.
The DB8 is garaged and is hardly driven since i drive the DA more for running erands.
Is it okay for a car to sit for 2 weeks w/out starting.
Should the oil be changed every 3 months even its doesn't reach 3000 miles?
Old Apr 10, 2006 | 03:33 PM
StolenTeg's Avatar
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (lalaine17)
Why not? i let my car sit over the winter
The oil doesnt need to be changed but before you drive it, that when you should change it if it was stored for a long period of time
Old Apr 10, 2006 | 03:40 PM
lalaine17's Avatar
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (StolenTeg)
i see.. why thank you for the tip
Old Apr 10, 2006 | 04:18 PM
iH8RICERZ's Avatar
2 weeks is fine..just make sure you warm up your car before you drive around. Change your oil after 3k miles (or whenever it starts getting dirty)....not every 3 months.
Old Apr 11, 2006 | 08:19 AM
lalaine17's Avatar
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (iH8RICERZ)
Thanks for the advise.. i appreciate it
Old Apr 11, 2006 | 05:27 PM
Cliffjumper2's Avatar
also it's a good idea to keep your gas tank full to minimize condensation while it sits for long periods of time
Old Apr 12, 2006 | 09:27 AM
lalaine17's Avatar
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (Cliffjumper2)
ohh okay.. I didn't know that. Thanks
Old Apr 12, 2006 | 12:40 PM
Wayne_Curr's Avatar
depends on the miles too...
I have 170k and let my DB7 sit for a week while on vacation and came back to a completely dead battery, flat tire and some seals dried out so my water pump started leaking, oil started leaking from the valve cover/cam seals...ugh...i think i'm fine now though =/
Old Apr 12, 2006 | 01:56 PM
lalaine17's Avatar
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (Wayne_Curr)
Thats not good to hear. I might as well drive my DB8 once a week then so no seals will get dried up.
Old Apr 12, 2006 | 04:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
A car will not end up that bad after only sitting a week. I left my car sitting outside my parents' house on the driveway for 17 days when I was in Europe last summer. Came home and it started right up no problem.
I, however, would not let the oil sit longer than 3 months. I'm guessing you probably don't put over 5K miles per year on the car? Would you really want to drive it on some oil that's been in the crankcase for nearly a year?
Old Apr 12, 2006 | 07:36 PM
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I, however, would not let the oil sit longer than 3 months. I'm guessing you probably don't put over 5K miles per year on the car? Would you really want to drive it on some oil that's been in the crankcase for nearly a year? </TD></TR></TABLE>
agreed
Old Apr 12, 2006 | 07:47 PM
1337whp's Avatar
chh i let my gsr sit for atleast 7months and it started right up fine! maybe its cus i used this
Old Apr 13, 2006 | 05:26 AM
Community Builder
Default Re: is it okay for a car to sit for 2 weeks w/out starting? Oil change 3k miles? (1337whp)
oh snap!! *runs out to check VTEC fluid level*
Old Apr 13, 2006 | 08:34 AM
lalaine17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I, however, would not let the oil sit longer than 3 months. I'm guessing you probably don't put over 5K miles per year on the car? Would you really want to drive it on some oil that's been in the crankcase for nearly a year? </TD></TR></TABLE>
Yes, you have a point there. Why thank you for the great tip.
Old Apr 13, 2006 | 01:51 PM
SilverDc2's Avatar
it should be fun, fill up the gas tank, they sell a product that you put in the gas, i would clean it up that way it doesn't smell moldy later..
PatrickGSR94
Aug 31, 2017 10:04 AM
slow99dx
16
Jun 12, 2005 03:44 PM
bad93ex
45
Mar 12, 2003 04:30 PM
MugenSiR
Sep 12, 2002 02:10 PM
Hard2Find
Jul 2, 2002 05:11 PM
