Which oxygen sensor - b16a2 swap with OBD1 ecu
Old Apr 10, 2006 | 03:04 PM
drumminforev's Avatar
Default Which oxygen sensor - b16a2 swap with OBD1 ecu
I have a b16a2 from a 2000 si USDM with a obd1 p30 ecu.
Which o2 sensors can i use. Do i have to use one for the 00 si or can i use one for the obd1 ecu, like 92-95 gen o2 sensor?
And is there anything wrong with buying o2 sensor that require splicing, or do i need to only buy the direct plug kind.
Thanks
Old Apr 10, 2006 | 03:14 PM
SVOboy's Avatar
Get a 4 wire. That's what the ecu wants at least, match the o2 to the ecu.
Old Apr 10, 2006 | 09:35 PM
Default Re: (SVOboy)
The 4 wires kind.. then i can just directly wire it in without fear of damage to ecu correct?
gitarman2
13
May 27, 2013 12:05 PM
A2gt35r
Engine Management and Tuning
11
Feb 21, 2009 03:05 PM
Ls1 FD3s
Aug 27, 2007 06:44 PM
Vtec's My Anti-Drug
Apr 22, 2007 04:02 PM
drumminforev
Nov 11, 2006 09:42 PM
