quick manual transmission question
Old Apr 10, 2006 | 08:23 AM
hyperforming's Avatar
Default quick manual transmission question
can i use a trans off a 92-95 ex/si sohc vtec on a 96-00 ex sohc vtec engine if i use the fly wheel and clutch from the 92-95 setup. the engine i would be using 96-00 would be an automatic the only fly wheel, clutch and tranny i have is a 94 si d16 trans good or no good any help greatly appreciated thanks
Old Apr 10, 2006 | 08:29 AM
5 Skware's Avatar
I missed the boat
Default Re: quick manual transmission question (hyperforming)
It will work just fine.
Old Apr 10, 2006 | 02:48 PM
thanks alot bro
Old Apr 10, 2006 | 06:41 PM
Bense's Avatar
92-95 trans/clutch/flywheels all bolt up no problems.
92-95 ex trans is the same as the 96-00 trans
92-95 si trans is the same as the 92-95 ex trans, only the si has a 0.750 5th gear instead of a 0.702 5th gear. The 0.75 is what makes the si "unique"
Jan in Omaha
13
Oct 2, 2010 09:17 PM
goldgreen90ef
Sep 25, 2008 06:16 AM
idriveadelsol7
Jul 13, 2005 02:33 PM
foz
Feb 22, 2004 06:35 PM
