For Sale D16z6 longblock!!!
Old Apr 9, 2006 | 10:31 PM
TehMoonRulz's Avatar
Default For Sale D16z6 longblock!!!
This 94 Si engine (longblock) was pulled from a Civic Si with side impact damage(92k miles).
This comes with:
Block (pistons,rods,crank, etc)
Head (cam/cam gear, valves, cover etc)
Intake manifold with throttle body
Vtec Solenoid
Sensors: Map, TPS, EAVC/IAVC, IAT
Original Distributor with BRAND NEW IGNITOR COIL
no fuel rail/injectors/exhaust manifold/timing belt/transmission
Engine is in parts (head/block) for easier transportation.
I promise nothing less, and you shouldn't expect anything more. But I may have forgotten minor **** posting this.
Needs two cam caps (easy **** from junk yard)
one exhust mani bolt (cheap)
$200 OBO
Old Apr 11, 2006 | 01:17 PM
Default Re: For Sale D16z6 longblock!!! (TehMoonRulz)
Bump
Old Apr 11, 2006 | 04:56 PM
Hybrid96EK's Avatar
Just FYI, if the cam caps need to be replaced (you said it needs two) then you will also need to line hone the cam journals. Just letting you know.
drlagares
Apr 15, 2018 11:39 AM
vfr700f2
11
Aug 31, 2009 07:44 AM
on2wheels
Jun 13, 2007 09:01 PM
DaveSi677
Oct 23, 2003 08:29 PM
