Camshaft
1 Post
Camshaft
Sorry guys i am still learnig everything that has to do with an engine. I have a D16Z6 and I would like to put a camshaft but would like to know if there is something that I should do before that like that is related.
Thanks
Thanks
Re: Camshaft (93SiVtec677)
get the whole valvetrain done if possible. also get a cam gear to go with it that way u wouldnt have to go back and replace your cam old cam gear with a new one. also just to make sure, check your timing belt and if u can replace it. with a bigger cam ur putting more stress on the lifters and springs. hope this helps
before cam..
1. exhaust
2. header
3. intake
depending on money
1. port polish head
2. 3 or 5 angle valvejob
3. aftermarket or y8 intake manifold
4. bigger throttle body and portmatch IM
5. higher compression pistons
depending on which cam
1. upgrade complete valvetrain
good cams for d16z6
1. zex 59300 (street/strip)
2. skunk2 cam
good cam gears
1. skunk2
2. aem
optional
1. get a vafc to set vtec/fuel/air/etc
2. chip your p28 depending on different programs
3. hondata
4. get it tuned FOR SURE
lots of variables
1. exhaust
2. header
3. intake
depending on money
1. port polish head
good cams for d16z6
2. skunk2 cam
good cam gears
1. skunk2
2. aem
optional
3. hondata
lots of variables
1 Post
Re: Camshaft (HXvtec)
thanks for clearing it up, WOWOW thanks for helping me so fast Honda-Tech really have valuable knowledgable people here!!!
Thanks for your help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 »</TD></TR><TR><TD CLASS="quote">thanks for clearing it up, WOWOW thanks for helping me so fast Honda-Tech really have valuable knowledgable people here!!!
Thanks for your help </TD></TR></TABLE>
read this, you'll be amazed as to what you can do with a sohc
<A HREF="https://honda-tech.com/zerothread?id=335078
" TARGET="_blank">https://honda-tech.com/zerothread?id=335078
</A>
</A>
you might also consider the mileage of the engine. I had a D16Z6 and at 120,000 miles, I installed a Zex/CompCams performance camshaft. Ever since then, the engine burned oil through the valve guides because the valve stems were already worn for stock lift, then when they were lifted further, they tore the valve guides up and it never did seal right...
Make sure your head is in very good shape before changing a cam. Huge clouds of smoke followed my car wherever I went thanks to that camshaft. Black crap all over the back of my car.
-zelif
-zelif
dustinbs144
06-03-2010 11:21 AM
DelSolDon
04-23-2005 09:52 AM
