00 Si Radiator fan wont kick on any suggestions?
Old Apr 9, 2006 | 10:07 PM
Ls_V_TurboSi's Avatar
Default 00 Si Radiator fan wont kick on any suggestions?
I have a stock si other than intake. I just put the motor in and for some reason the radiator fan wont kick on. I searched this problem before making this post and I've done what they have recommended in those post..
Checked the fuse under the dash and changed the relay under the hood- no fix.
I changed the switch on the thermostat housing . No fix
I changed the thermostat. no fix
I jumped the connector plug and the fan does kick over so I know the fan is good. What else should I check?
Old Apr 9, 2006 | 10:15 PM
professor poon's Avatar
well if you jumped the connector plug and it worked then isnt it the connector plug? And how is your car stock if you just did a motor swap?
Old Apr 9, 2006 | 10:16 PM
CBEengineering's Avatar
Default Re: 00 Si Radiator fan wont kick on any suggestions? (Ls_V_TurboSi)
ecu?
Old Apr 9, 2006 | 11:38 PM
E46Kid's Avatar
do you know if the radiator fan even works? since u say u swapped the motor?
Old Apr 9, 2006 | 11:46 PM
b18 EK9's Avatar
check the thermo temp switch thats prolly it
Old Apr 9, 2006 | 11:59 PM
E46Kid's Avatar
Default Re: (b18 EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 EK9 &raquo;</TD></TR><TR><TD CLASS="quote">check the thermo temp switch thats prolly it</TD></TR></TABLE>
did you read? it says he did
Old Apr 10, 2006 | 01:12 AM
nello a.'s Avatar
wiring to the switch is about all that is left
Old Apr 10, 2006 | 09:38 AM
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">well if you jumped the connector plug and it worked then isnt it the connector plug? And how is your car stock if you just did a motor swap? </TD></TR></TABLE> I didnt do a motor "swap" I put the original motor back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering &raquo;</TD></TR><TR><TD CLASS="quote">ecu?</TD></TR></TABLE>
Doubtful, But I guess its worth a shot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkSi &raquo;</TD></TR><TR><TD CLASS="quote">do you know if the radiator fan even works? since u say u swapped the motor?</TD></TR></TABLE>
When you jump the connector it kicks on the fan. and it did do that so I know it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">wiring to the switch is about all that is left</TD></TR></TABLE> I dont think its the wiring since the wiring all the way up to the connector works and the fan actually turns on. Man this sucks.
Old Apr 10, 2006 | 09:56 AM
Metalluthier's Avatar
Usually if your O2 sensors aren't in good order your fan won't kick on. Another common problem with this is, bad circulation and input. If your computer doesn't know your engine is running hot, it won't kick in at proper intervals. I'd check to see if you've got **** clogged in your intake.
Old Apr 10, 2006 | 11:23 AM
ILUVMYEM1's Avatar
Possible thermostat or fan switch.....
Old Apr 10, 2006 | 11:47 AM
old man neri's Avatar
Default Re: 00 Si Radiator fan wont kick on any suggestions? (Metalluthier)
A few simple questions.
Is it actually overheating? (It's a dumb question but I want to get it out of the way)
Is it fully bled?
Old Apr 10, 2006 | 02:00 PM
Default Re: 00 Si Radiator fan wont kick on any suggestions? (old man neri)
We bled it by letting it run for about 20-30 minutes without the radiator cap on. It was overheating, smoking and bubbles were coming out like crazy until we wired up the fan after that the system went to normal. Since then the only time it had overheated was yesterday when we were messing with the thermostat now it runs like a champ. I went and registered it today and ran a few errands and it runs perfect but I know the fan isnt working. Which annoys me becuase when I sell it I want to sell it perfect not half ***.
Old Apr 10, 2006 | 02:06 PM
You sure it was bubbling because it was boiling or bubbling because air bubbles were coming out? I have seen people confuse the two before.
Final check, before you park the car let it idle for a while. If it doesn't over heat you are laughing.
Old Apr 10, 2006 | 02:20 PM
I believe it was bubbling becuase it was overheating (boiling) due to the fan not coming on. as soon as we hooked the fan up the smoke went away and the bubbles went away and the temp went to normal. We topped off the radiator and the car runs fine and doesnt overheat even when its idling. BUT the fan doesnt come on and I want that problem fixed..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
If it doesn't over heat you are laughing. </TD></TR></TABLE>
??? Please emphasize
Old Apr 10, 2006 | 04:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote"> We topped off the radiator and the car runs fine and doesnt overheat even when its idling. BUT the fan doesnt come on and I want that problem fixed..
If it is not overheating then there is no reason for the fan to come on. The fan is only used for when the car is at a stand still but not necessarily if the car is at a stand still the fan will engage. If you car is at a stand still and the temp guage is roughly the same spot it would be on the highway then you are fine. If however you are at a standstill and the temperature guage is climbing a considerable amount but the fan is not kicking in then you do have a problem. (This is of course all with the engine having been run up and brought to operating temp)
We roughly on the same page?
Old Apr 10, 2006 | 05:20 PM
Dodger2940's Avatar
I had the same problem and a trick to know if the fan is working is to turn on the AC if both the AC fan and the radiator fan work, your good. If the AC fan turn on and the radiator fan doesnt ( like me) then the only option is to wire the fan to a switch.
I hope someone knows how to fix this problem.
hondacivic984dr
Mar 21, 2007 04:57 PM
dragaholic
Jul 29, 2006 11:43 PM
SpoonREVS
Jan 24, 2006 05:42 PM
89HFlikeamutha
Aug 13, 2004 01:18 PM
