First time racing at 1/4 mile track what should i do when i get there to prep?
Old Apr 5, 2002 | 01:51 PM
yellowbuffalo's Avatar
Default First time racing at 1/4 mile track what should i do when i get there to prep?
its my first time at the track and i would like to know if I should be doing anything in particular to get ready once im there?
Old Apr 5, 2002 | 02:25 PM
hybridreams's Avatar
Default Re: First time racing at 1/4 mile track what should i do when i get there to prep? (slipknot23)
1. Change your oil and check your fluids the night before
2. Don't rape your car on the way to the track
3. Put your heat VENT on, I usually only leave it at 1 when I'm running
4. Remember staging etiquette
Anyone want to add anything? I think the ice on the intake manifold, etc. is pushing it
[Modified by hybridreams, 6:25 PM 4/5/2002]
Old Apr 5, 2002 | 02:29 PM
Default Re: First time racing at 1/4 mile track what should i do when i get there to prep? (hybridreams)
why turn on the heat vent?
Helps remove heat from your engine bay
Old Apr 5, 2002 | 02:46 PM
seatownGSR's Avatar
Can you explain proper staging etiquite? I am going for my first time as well soon.
Old Apr 5, 2002 | 02:57 PM
B00ST2nR's Avatar
You serious? So if you turn on the heater at 1, it will help your car run better?
Old Apr 5, 2002 | 03:02 PM
Default Re: First time racing at 1/4 mile track what should i do when i get there to prep? (seatownGSR)
No prob - check this link out:
http://www.nhra.com/basics/index.html
Just make sure you remain pre-staged until the other car is pre-staged. You can fully stage after the other car is pre-staged. Just staging courtesy.
Old Apr 5, 2002 | 03:05 PM
Default Re: First time racing at 1/4 mile track what should i do when i get there to prep? (GS-R)
do i sense sarcasm? smart ***
don't expect to knock off half a second or anything, it's just one of those things you do to help out. im sure if your motor could talk he'd appreciate you taking some heat out of there
[Modified by hybridreams, 12:05 AM 4/6/2002]
Old Apr 5, 2002 | 04:29 PM
threatcon13's Avatar
New User
make sure you put your springs in the right place so that your car doesnt look like an off roader(front wheels higher than back from what i remember when hearing bout your car last time)
Paluce
10
Nov 17, 2006 09:59 PM
Nuts
Dec 20, 2001 09:05 AM
Xerzex
Oct 1, 2001 09:37 PM
