Low oil
Old Apr 9, 2006 | 09:00 PM
RiCE On IcE 2's Avatar
Default Low oil
Will low oil cause erratic engine performance (i know vtec won't engage but will it also cause power to drop off and then spike in the upper rpms?) The light was not one when this was occuring but eventually it went on and now it seems like after a fill the motor is running ok. Would all that be caused by low oil levels?
Additionally it seems I'm burning 2qts or mobil 1 per 3k miles is that excessive?
Old Apr 9, 2006 | 09:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Low oil (RiCE On IcE 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">it seems I'm burning 2qts or mobil 1 per 3k miles is that excessive?</TD></TR></TABLE>
No.
Old Apr 10, 2006 | 08:48 AM
Default Re: Low oil (nsxtasy)
gees, thats actually normal? Note, I'm not driving hard at all.
Old Apr 10, 2006 | 09:01 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
IMHO that slightly excessive especially if your not in it alot.
Another note never look for the oil light as a low on oil indicator. If the oil light comes on then most of the time your too late. Check you oil whenever you fill up with gas!! A new motor is expensive.
Old Apr 10, 2006 | 10:30 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Low oil (walker111)
One quart every 1500 miles is not excessive.
One quart every 150 miles is excessive. But that discussion is in a separate topic.
Old Apr 10, 2006 | 10:37 AM
type_r_jon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">Will low oil cause erratic engine performance (i know vtec won't engage but will it also cause power to drop off and then spike in the upper rpms?) The light was not one when this was occuring but eventually it went on and now it seems like after a fill the motor is running ok. Would all that be caused by low oil levels?
Additionally it seems I'm burning 2qts or mobil 1 per 3k miles is that excessive?</TD></TR></TABLE>
Just don't let the oil get low, I check mine constantly. I burn all the time no matter what kinda driving I do. You want an R its part of the price.
O and there is a cagillion threads on this do us both a favour and search.
Old Apr 10, 2006 | 04:36 PM
vtakvtrak's Avatar
Default Re: Low oil (type_r_jon)
i burn about half a quart every 1500 miles on my b18c1 motor
Old Apr 10, 2006 | 06:05 PM
JjuuN R's Avatar
ok, you say you knew it was running low on oil and you knew about it, then the oil light eventually came on, why in the hell would you wait for the oil light to put oil in if you knew it was needed??
Old Apr 10, 2006 | 07:01 PM
lalo's Avatar
Default Re: (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">ok, you say you knew it was running low on oil and you knew about it, then the oil light eventually came on, why in the hell would you wait for the oil light to put oil in if you knew it was needed??</TD></TR></TABLE>
THATS TRUE.......
BUT FOR YOUR PROBLEM , I THINK ITS LOW COMPRESSION ON YOUR MOTOR, THATS WHY U KINDA FEEL IT WEAK WHEN ITS IN USE....LOW OIL CUSE ALOT OF PARTS TO WEAR OUT...." ITS LIKE WATER IN A HUMAN BODY "
Old Apr 10, 2006 | 07:44 PM
00MRSi's Avatar
Default Re: (lalo)
You're lucky your motor didn't burn up.. It would be a good idea to check your oil at least once a week..
Old Apr 10, 2006 | 08:20 PM
lalo's Avatar
Default Re: (00MRSi)
Old Apr 11, 2006 | 12:00 PM
Default Re: (JUN.R)
I never said I never knew it was running low. I had refilled it like 1500-2000 miles before the light was on so I did not think my oil was low until the light came on.
dmaldon
Jun 1, 2017 02:31 PM
TinoNT
Apr 26, 2013 01:34 AM
HYREV2NR
Honda Fit
80
Oct 6, 2008 02:00 PM
DC_RaceR
Feb 23, 2006 02:00 PM
allmotorEG-SI
Nov 22, 2003 11:11 AM
