first post with my new EK, lock button doesnt work?
Old Apr 9, 2006 | 04:12 PM
clemsonteg's Avatar
Default first post with my new EK, lock button doesnt work?
well I just picked up a 98 ex coupe, and the first thing I have found on it is when I push the lock button, the passenger side will lock and unlock but the driver side door wont, is that normal or do i need to replace the lock motor?
Old Apr 9, 2006 | 05:23 PM
old man neri's Avatar
Default Re: first post with my new EK, lock button doesnt work? (clemsonteg)
Look for some loose connections. It happens now on then after a while.
Cheers.
Old Apr 9, 2006 | 05:32 PM
x justin's Avatar
Normal
You can only lock it with the key from the outside or using the keyless entry (if you have it). I guess it's so you can't lock your keys in the car.
Old Apr 9, 2006 | 06:04 PM
clemsonteg's Avatar
Default Re: first post with my new EK, lock button doesnt work? (justin:)
I was just wondering cause even with the door completely shut it wont do it, but im gonna get an alarm and keyless anyways
Old Apr 9, 2006 | 06:12 PM
Mark D. Surface's Avatar
You have to pull the handle then push the lock button.
Old Apr 9, 2006 | 06:15 PM
Targa250R's Avatar
be professional
Default Re: first post with my new EK, lock button doesnt work? (Mark D. Surface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark D. Surface &raquo;</TD></TR><TR><TD CLASS="quote">You have to pull the handle then push the lock button.</TD></TR></TABLE>
That's only when the door is open. With the door closed, the lock switch should function normally.
Something is likely wrong with the lock actuator.
Old Apr 9, 2006 | 06:18 PM
Default Re: first post with my new EK, lock button doesnt work? (Targa250R)
Sorry wasn't specified opened or closed. Sometimes the littlest problems are over looked!
Old Apr 9, 2006 | 06:31 PM
clemsonteg's Avatar
thats what i needed to know, guess ill hit up hondaautomotiveparts.com and grab an actuator, i guess the driver side would be the left side, shouldnt be more than 50 bucks
Old Apr 10, 2006 | 06:23 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonteg &raquo;</TD></TR><TR><TD CLASS="quote">well I just picked up a 98 ex coupe, and the first thing I have found on it is when I push the lock button, the passenger side will lock and unlock but the driver side door wont, is that normal or do i need to replace the lock motor?</TD></TR></TABLE>
My car does the same thing. I can lock both sides with the lock buttonif the door is closed, which is retarded since you cant get out without unlockign the door . I have to lock the driver side manually with my key so I dont have keyless or an alarm or anything
EBP_Em1
Honda Civic (2006 - 2015)
Sep 21, 2015 04:56 PM
RevrsOne
Aug 18, 2012 03:43 AM
preludexl
16
Jun 15, 2008 03:55 PM
oc_civic
10
Nov 23, 2005 10:37 AM
