Tank level indicator
the sending unit is located inside the tank.....you can get to it from top of tank,,in the trunk ..
find the plug that goes to sending unit.. chk the black wire make sure it has a good ground,, if it does not, repair the ground,,, and retry it
if ground is good,, ground the yellow/blue wire , put key on, gauge should go all the way to full, if it does you got a bad fuel sending unit, replace it and retry..
if gauge does not go up, you could have a bad gauge or bad wiring from sending unit to gauge ..
do the tests and post the results
dejay2014
Jul 15, 2015 01:25 PM
