Need Help..cant get underdrive pully off!!! Any suggestions???
Old Apr 9, 2006 | 02:04 PM
PrestonCRX's Avatar
Default Need Help..cant get underdrive pully off!!! Any suggestions???
I dont think it's ever been taken off. It's on there pretty good, tried to even break it with the starter motor but it wont break loose. Any suggestions on how to do this?
Old Apr 9, 2006 | 02:05 PM
.Manny.'s Avatar
Touching My Member
impact gun! works wonders
Old Apr 9, 2006 | 02:19 PM
PrestonCRX's Avatar
Default Re: (90_EF_Si)
tried the air gun no luck......... even broke my air gun 17mm
Old Apr 9, 2006 | 05:40 PM
PrestonCRX's Avatar
Default Re: (PrestonCRX)
bump
Old Apr 9, 2006 | 06:15 PM
UltimX's Avatar
put ur car on the ground, put blocks in back of the back tires, front on the front tires, get a 1/2" ratchet w/ impact socket, use a braker bar and take it off. Its easy.
Old Apr 10, 2006 | 07:42 AM
PrestonCRX's Avatar
Default Re: (UltimX)
i tried everything nothing worked yet keeping updated..............
Old Apr 10, 2006 | 07:59 AM
gnar kill's Avatar
get a bigger air gun....the only time this hadn't worked was on my 4 door accord when I was using a 1200 ft lb half inch drive airgun so I used the torch to get the bolt hot (not too hot) and the thing came out like butter.....don't know if you want to go this route but get a bigger airgun and some impact (black) sockets
Old Apr 10, 2006 | 08:04 AM
PrestonCRX's Avatar
Default Re: (gnar kill)
i have a 1/2 drive air gun i was trying that i probley will try the heating up idea today and yeah it was a black impact gun 17mm lol snapped the side right off lol
Old Apr 10, 2006 | 09:31 AM
exsinnovation's Avatar
try using a breaker bar and extend it with a longer pipe?
Old Apr 10, 2006 | 10:50 AM
PrestonCRX's Avatar
Default Re: (exsinnovation)
SO I TOOK THE BLOCK TO MY BUDDIES DADS GARAGE AND TOOK THERE AIR GUN TO IT WORKED LIKE A CHARM ...CAME RIGHT OFF I THINK IMA HAVE TO GET A BIGGER AIR COMPRESSOR
PatrickGSR94
Jun 14, 2007 05:50 PM
Kiniku Chunks!!!
Sep 13, 2006 09:43 AM
lv6l
12
Oct 26, 2005 06:51 AM
xjohnx
Nov 22, 2001 10:09 PM
AWDSOME
Aug 29, 2001 03:30 AM
