Car wont start
im having problems my car wont start as the title says. its not the battery or anything basic. when i turn the key over it acts like it wants to start but it wont. think its the starter?
if it's the starter , it can to turn when you turn the key or not.. but if it turns, it's possible that it doesnt has enough power for the engine, or too your engine doesnt has spark.. or too your fuel pump isnt working..
well first thing you want to check is the fuses before you start spending money theres a fuse box under the dash and under the hood if the fuses are fine,pull out every spark plug and see if any of them are getting spark if none of them are getting spark then check the wires if there cracked replace then check the distubuter see if theres any cracks if so replace if not take off the cap and check the rotor if all thats fine its your ignition coil
ej2civic
11
Mar 5, 2007 12:40 PM
