1997 - OBDI or OBDII ?
Old Apr 9, 2006 | 08:50 AM
amorak's Avatar
Default 1997 - OBDI or OBDII ?
TOpic says it all, is the 97 Civic OBDI or OBDII. I was under the impression that all cars built after 96 had to be OBDII, but I heard Honda was still OBDI?
Old Apr 9, 2006 | 09:08 AM
SVOboy's Avatar
OBDIIa
I think all cars were obdII then, some were obdII earlier also.
Old Apr 9, 2006 | 09:23 AM
G2 Speed's Avatar
Default Re: (SVOboy)
all above 96 is correct
Old Apr 9, 2006 | 09:57 AM
amorak's Avatar
Default Re: (G2 Speed)
What's the best way to check codes then? an OBDII scanner obviously, but is there a certain, better version for Hondas (akin to the VAG-COM that the VW guys use, which is a fantasic unit, able to program so many interesting features!)
As a side note, are their any OBDII cables that would interface with either a laptop or a PDA?
Old Apr 9, 2006 | 10:13 AM
G2 Speed's Avatar
Default Re: (amorak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amorak &raquo;</TD></TR><TR><TD CLASS="quote">What's the best way to check codes then? an OBDII scanner obviously, but is there a certain, better version for Hondas (akin to the VAG-COM that the VW guys use, which is a fantasic unit, able to program so many interesting features!)
As a side note, are their any OBDII cables that would interface with either a laptop or a PDA?</TD></TR></TABLE>
just get an obd2 scanner, there cheap ..... 200-300 bucks..... and u just won't use it once...
Old Apr 9, 2006 | 12:39 PM
drevinder's Avatar
not just honda any car that is made from 96 and up is obd-2
Old Apr 9, 2006 | 01:38 PM
kiddcarbuff's Avatar
del sol vtec was obd1 until production ended in 97. correct me if im wrong?
Old Apr 9, 2006 | 02:33 PM
TspEk9's Avatar
96-97 del sol are obd2 since the ecu plugs were different, cause i ran one in my ek
vile10
Jan 13, 2008 07:25 PM
TeknoGroover
Apr 10, 2005 03:36 PM
crxhybrid85
Mar 7, 2005 05:04 AM
Miz101
Oct 8, 2003 08:06 PM
mandrews
Feb 20, 2003 09:03 AM
