Having trouble Removing Knuckle
Old Apr 9, 2006 | 02:45 AM
LaOstha's Avatar
Default Having trouble Removing Knuckle
Im tryin to take m knuckle off so i can bring into a shop to change my bearing. But the lower ball joint doesnt want to slide out. I would tap the screw wit a hameer but i dont want squish it and ruin the threads. any sugestions?
Old Apr 9, 2006 | 03:29 PM
LaOstha's Avatar
Default Re: Having trouble Removing Knuckle (LaOstha)
ttt
Old Apr 9, 2006 | 07:24 PM
bnock's Avatar
spray it with wd40on the bolt, put a peice of wood on the underside of the lower arm and tap it up with with a hammer
Old Apr 9, 2006 | 11:01 PM
LaOstha's Avatar
Default Re: Having trouble Removing Knuckle (bnock)
but wouldnt it ssquish it too? since that hole is there for the cotter pin i know i willl squish it.
Old Apr 10, 2006 | 10:24 AM
LaOstha's Avatar
any one>?
Old Apr 10, 2006 | 10:29 AM
egredspools's Avatar
there is a trick 2 it if u put a piece in where... depending on the side pretend ur on the right side lookin at it to the right there is tiny gap put sumthing that fits in there and the leverage from the knuckle pushing the lower arm when lowering would pop out????worked for me when it was stuck
Old Apr 10, 2006 | 10:38 AM
pdiggitydogg's Avatar
http://www.hstuners.com/forums...24308
https://honda-tech.com/zerothread?id=887859
Old Apr 10, 2006 | 10:49 AM
LaOstha's Avatar
Default Re: (pdiggitydogg)
THANKYOU pdiggitydogg i apreciate it
Old Apr 10, 2006 | 11:02 AM
Baggy Spandex's Avatar
Default Re: (LaOstha)
Honestly, the best way to detach the ball joint/Knuckle...get a huge friggen hammer, and SMASH the hell out of the front of the LCA. The shock will eventually pop it loose in like 5 hits.
Ask any Honda Technician, he'll tell you the same thing.
Old Apr 10, 2006 | 11:06 AM
Work smarter, not harder
Old Apr 10, 2006 | 11:29 AM
LaOstha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Work smarter, not harder</TD></TR></TABLE>
Old Apr 10, 2006 | 11:36 AM
thats exactly what i said
C00kiemunstr
Oct 1, 2008 02:55 PM
miguelv0723
Nov 11, 2006 04:26 PM
JDM_SOHC
12
Mar 29, 2006 05:44 AM
LX4CYL
16
Feb 13, 2005 03:12 PM
slooogsr
28
Jul 21, 2003 03:30 PM
