Location of 1997 Civic Sedan SRS Module??
Old Apr 8, 2006 | 09:53 AM
camano's Avatar
Default Location of 1997 Civic Sedan SRS Module??
My daughter's recently purchased '97 Honda Civic SRS light was on when she got it so she took it into the dealer to have it checked. They said they tried to reset it but were unable to. They want unit $780 to replace the unit! I have found modules on eBay but was wondering where on the car the module is located? Is behind the passenger dashboard panel? THanks for any help!
Stan
Old Apr 8, 2006 | 09:57 AM
123_vtec's Avatar
Right behind the center console at the firewall side. May need to lift the carpet up a little. You will need to use the star allen wrench size T30 to unscrew the 4 screws in order to get it loose. Then unplug the connectors and it'll slide out. Oh, dont forget to unplug your battery just to be on the safe side.
Old Apr 8, 2006 | 09:58 AM
Crx Jimmy's Avatar
Default Re: Location of 1997 Civic Sedan SRS Module?? (camano)
try here
https://honda-tech.com/zeroforum?id=1
Old Apr 8, 2006 | 10:29 AM
camano's Avatar
Default Re: (123_vtec)
Thanks 123! I will take a look at it later today.
Old Apr 8, 2006 | 10:30 AM
camano's Avatar
Default Re: Location of 1997 Civic Sedan SRS Module?? (Crx Jimmy)
crx -
The link took me to a page with many posts - did not see on related to the SRS location.
Old Apr 8, 2006 | 03:04 PM
pinecone's Avatar
He was showing you how to get to the 92-00 civic forum. You posted in the CRX/EF Civic forum, two totally different cars.
Old Jun 18, 2011 | 08:27 AM
jimbabwe's Avatar
I know this is an old thread, but I recently had to replace an SRS module on a 1997 Honda Civic DX 1.6 Manual Transmission. I searched the web and didn't find a clear explanation of the SRS Module location. I finally found downloadable service manuals on EBAY in a store run by royal.outlook.
I'm posting this on an old thread so maybe somebody else will benefit. I bought a used SRS module on Ebay and saved myself somewhere around $600 bucks or more on a 20-25 minute job.
I also put together a simple how-to with pictures, but don't see a place to upload the how-to, so I'll spell it out briefly in this response.
DISCONNECT THE BATTERY BEFORE REPLACING THE MODULE!
On my 1997 Civic DX if you look at the floor-level to the right of the gas pedal, you will see a black plastic cover just under where the dashboard begins. This is held in by a plastic screw. Remove the screw and pull the cover off.
Under the cover is a yellow wiring block-connector connected to the SRS module. Grab the yellow wiring block-connector (about 3 inches wide), rock it and pull until it disconnects from the SRS module.
You will see two T-screws (star screws). Remove these (I had to use a little liquid wrench to get one of the two loose).
Go to the passenger side and look for a similar black plastic cover in nearly the same location. Remove the plastic screw from the passenger side cover and then remove the cover.
You will see (again) two T-screws (start screws). Remove these (again, I had to use a little liquid wrench on one of the two screws to get it loose).
Remove the SRS module and put in the replacement SRS module.
Re-install the 4 star screws, re-attach the yellow wiring connector block to the new SRS module.
Re-install the black plastic covers.
Re-attach the battery.
Start the car and check for the SRS light going out like it is supposed to.
I didn't have to reset the replacement SRS module (even though it was used). If the light is still on, Google for how to reset the SRS module using a paper clip. If the light is still on, try to reset a couple of times. If the light stays on, either the new module is no good or you might have to look for something wrong with the seatbelt part of the SRS warning (Google this).
Old Jun 18, 2011 | 09:09 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The only thing is - this Zombie thread is still in the wrong forum. I highly doubt people would come looking in here for this information.
Old Jun 18, 2011 | 01:05 PM
BiG ChOr!Zo's Avatar
Old Jun 9, 2012 | 12:42 PM
yoshiki2's Avatar
besides the control module.. is there any sensor I need to replace? any on the front bumper?
Old Jun 9, 2012 | 05:09 PM
Former User's Avatar
No. The sensor is built into the control unit.
Old thread closed.
devsiri
Mar 29, 2013 10:30 AM
civicawesome
Honda Civic (2001 - 2005)
Mar 25, 2013 09:15 PM
MORANA
Apr 14, 2008 04:19 PM
pkx
Feb 7, 2006 09:26 AM
Mike Ockhurts
41
Mar 13, 2003 04:47 PM
