radio died, cel comes on, speedo dies, dimming lights???????
what the heck is going on with my car this, all came out of the blue...... has anyone had similar problems? all my fuses are good, cleaned my vss and plug, cel flases code 65, 41, 2, but it was all fine before all this crap happened. help!!
YEAH ITS YOUR ALTERNATOR IF U PUT A NEW BATTERY IN U CAN DRIVE FOR ABOUT AN HOUR UNTIL IT DRAINS BUT BESST BET IS TO BUY A NEW ALTERNATOR I USED THE ONE OFF OF MY OLD EF JUST CHANGED THE PULLEYS AROUND LET ME KNOW IF THIS WORKED
yeah, you got a bad alternator or connection to it. check the 12ga wire or whatever going to the alternator, then check the other end at the fuse panel. if neither is loose its your alt.
the_illest_soldier
Sep 10, 2005 03:12 PM
