EK swap,help pick OBD 1 or 2 motor...
Old Apr 7, 2006 | 04:16 PM
Samuels's Avatar
Default EK swap,help pick OBD 1 or 2 motor...
I'm thinking about possibly picking up a 99 EK hatch sunday for a swap after selling my ls/turbo eg..
The guy had a SOHC VTEC in the car and has the obd-2 to obd-1 harness..
I'm down to a h22 swap which i can get for 2k local but would need mounts 600 dollers and possibly a shift linkage not sure though..
A LS swap for another turbo LS
A B16 swap for turbo..
Here is the problem the car is obd-2. I really want a 0bd-1 motor so i can run uberdata like on my EG
My eg put down 225hp on 10lbs on a stock motor i'm looking to make about the same power with this setup.
If I get a h22 swap i will probably put on a 50 shot with bolt on's..Either the b16 or the LS will be boosted..
If I buy the obd-1 swap what do i need to make this work exactly??
If I buy a obd-2 swap what would need to be done to convert it to obd-1??
The guy has a obd-2 to obd-1 conversion harness but i'm not sure how it works..Will the ek plugs plug into the obd-1 motor like plug and play??
If I decide to do a h22 the least likely of the 3 i will buy a obd-2 motor swap its just gonna be a much more expensive swap..
i've searched this so please no flaming just help a brotha out..
Old Apr 7, 2006 | 04:21 PM
tomu06's Avatar
Default Re: EK swap,help pick OBD 1 or 2 motor... (Samuels)
to use a uberdata or hondata you just use a obd1 ecu like a p28 and chip them..
Old Apr 7, 2006 | 04:32 PM
Samuels's Avatar
Default Re: EK swap,help pick OBD 1 or 2 motor... (tomu06)
For example could I buy a obd-2 LS motor,tranny,axles etc basically get the tranny mount thats needed and drop it in and it be plug and play has far has plugs plugging right up like a LS in a EG is??
Then just run the obd-2 motor off of a chipped P06 obd-1 ecu with uberdata useing the jumper harness for the ECU to go from obd-2 down to obd-1??
What needs to be changed??
Sorry for being a newb i've just never messed with this obd-2 crap but i sold my eg wanting a ek for the look and never researched the bs beforehand..
Old Apr 7, 2006 | 06:40 PM
Samuels's Avatar
bump it up...
Old Apr 8, 2006 | 04:19 AM
Samuels's Avatar
anybody know??
Old Apr 8, 2006 | 04:22 AM
fmrprojects's Avatar
you buy a obd-2 motor so it would be easier to swap the harness. and then to run obd-1 ecu, all you need is the jumper at the ecu and a obd-1 ecu. everything in the engine bay is obd-2
Old Apr 8, 2006 | 09:32 PM
VtecnTurbo's Avatar
if you plan on using bigger injectors you will have to use the obd1 plugs for them. if you liked uber you will love crome.
Old Apr 8, 2006 | 10:34 PM
ccjustin's Avatar
Am I the ony person that checked with the registry? You can't pass with an obd1 computer in an obd2 car, least not in Mass
tougetuned_ef
Mar 7, 2009 07:11 PM
Civic5Lug
Feb 13, 2004 06:17 AM
h22dx
Jan 29, 2003 10:53 AM
BigBlockCRX
Aug 28, 2002 03:25 PM
