Spring Rate Question..
I found a great set of Cusco Comp S Coilovers. My question is the guy has the spring rates listed as 8k in the front, 6k in the rear. My car is mostly a street car. Are these rates too stiff for the street? I am willing to sacrifice a little comfort, I'm just not looking for something that is going to be breaking my tailbone.
Thanks in advance guys.
-Eric
-Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa »</TD></TR><TR><TD CLASS="quote">Those rates should be fine assuming the dampers are decent quality.</TD></TR></TABLE>
They are part of the Cusco Comp s Coilovers so I am assuming they are very good quality.
Anyone have any experience with these?
the quality will be fine, iirc they are made by showa. the only issue with the comp s is the ride height adjustability is not independant. i would expect as with most jdm coilovers for the shock to be valved on the stiff side. i thought about these but instead decided to go with the spoon dampers and progressive springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver j »</TD></TR><TR><TD CLASS="quote">the quality will be fine, iirc they are made by showa. the only issue with the comp s is the ride height adjustability is not independant. i would expect as with most jdm coilovers for the shock to be valved on the stiff side. i thought about these but instead decided to go with the spoon dampers and progressive springs.</TD></TR></TABLE>
When you say the ride height adjustablity is not independent, what do you mean by this?
maybe this will make a little more sense. take a look at the difference between the comp-s and zero1. it goes into detail right after the description of the zero1
http://www.cusco.co.jp/english/e_cont.html
JDM PRO
Apr 2, 2004 12:06 PM
